Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 08-02-2003
ALaz502 ALaz502 is offline
Junior Member
ALaz502 is on a distinguished road
Question Which drum sequencer can do these things...
Hi, I'm fairly new to home recording, and I've been recording a few things but the main thing I'm having trouble with is drums.
I'm currently using Fruity Loops and I got some decent samples, but my drum beats just sound too..."straight." I can't really use any odd time signatures and I can't change tempos in the middle of a song.
So...my question is which drum sequencer can do all of these things..
1. Export to Wav
2. Have different tempos within one song.
3. Have different time signatures within one song.
(Being able to change time signatures on each drum/cymbal individually would be a bonus as well)
4. Use outside samples.
Fruity Loops has 1 and 4 covered...but I feel somewhat frustrated when I have to create a new file and paste it into the song in order to switch tempos, and there's absolutely no way that I've seen in which you could change time signatures.
I'm getting sick of the standard 1, 2, 3, 4 crap and I can't find a decent metal drummer out here.
PLEASE HELP.
N/P: Meshuggah/Destroy Erase Improve/Future Breed Machine
Old 08-02-2003
TimOBrien TimOBrien is offline
2.5K Gold Member
TimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond repute
Actually, you could do it with Fruity.
Just do each section separately, export the .wavs and then combine each setion together in your main sequencer program.
Not really difficult, just not all in one go....
Old 08-02-2003
Junior Member
So how do you change the time signatures in Fruity Loops? I've only been able to do standard 1,2,3,4 stuff.
BTW...the reason that I don't like doing it that way, is sometimes after I'm finished putting the patterns together, I like to adjust the panning, etc. If I do it that way, I have to make sure that each separate section is equally panned, etc, and that could be a pain.
Old 08-03-2003
jake-owa's Avatar
jake-owa jake-owa is offline
Banned
jake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud of
Well I sound like a broken record but check out the Yamaha QY70...
Old 08-04-2003
Junior Member
Question
Is that software or an actual drum machine?
Old 08-04-2003
jake-owa's Avatar
Banned
G O O G L E
It's your friend.
http://www.google.com/search?hl=en&i...&q=Yamaha+QY70
Old 08-05-2003
Junior Member
DoH!
Hmm...a little out of my league, I don't need anything THAT professional.
Anything in software?
Old 08-05-2003
flapo1's Avatar
flapo1 flapo1 is offline
Dedicated Member
flapo1 is on a distinguished road
You can certainly do that with FL (except MAYBE point 3)
Saludos Amigos
Old 08-06-2003
Junior Member
So it's possible to change the tempo(and I don't mean just cutting it in half or doubling it) in Fruity Loops without having to make seperate files and pasting them together in Sonar?
How do you do that?
Old 08-06-2003
flapo1's Avatar
Dedicated Member
Yes, sir there is a way.
I don't remember exactly right now because I'm at the office, but search for a "tempo map" in the help file.
Saludos Amigos
Old 08-06-2003
Junior Member
Tempo map...thank's a lot, I'm at the office as well. I'll check it out tonight.
  #12
Old 08-08-2003
Chrisjob Chrisjob is offline
prolegomena
Chrisjob is on a distinguished road
Record tempo-changes with live automation, then open the file, and find tune them (under current project)
I always use the piano roll to program everything, so you can move you hits to loosen up the feel, or to push the groove. Stay away from the step sequencer unless your making electronic music.There;s a little box in the top left corner of the step sequencer (in FL studio only) next to a double headed arrow where you can select the beats per measure for each pattern. Works in Step and Piano Roll mode
If you use the Piano Roll, just change your snap features to whatever time signature you need.
Good luck,
Chris
  #13
Old 08-09-2003
Junior Member
Smile
Wow! Thanks a bunch!!
all you guys on this board are so extremely helpful!
I guess I don't need anything other than Fruity Loops
  #14
Old 08-11-2003
flapo1's Avatar
Dedicated Member
Chris:
I use the step sequencer and I can push or pull the feel by using the "shift" feature. Are you familiar with it?
Saludos Amigos
  #15
Old 08-16-2003
prolegomena
I've used the shift feature, but I just like to set my hit exactly where I want it. You can also double click on each hit, and fine tune it's exact position in the beat
Also, you can make a piano roll sequence as long as you want, like for a whole verse or chorus. It really cleans up you playlist
And you can use the groove files..
And the chopping...
And you can zoom in and out...
And there's four colors to choose from....
It's the bomb.
Boom.
-Chris
  #16
Old 08-17-2003
Fusion2 Fusion2 is offline
Force of Nature
Fusion2 is on a distinguished road
this forum needs a fruity section for sure...
god i luv that soft
  #17
Old 08-18-2003
flapo1's Avatar
Dedicated Member
god i luv that soft
I second that!
Saludos Amigos
  #18
Old 08-18-2003
Force of Nature
How do you do that?
the record button keeps track of temo changes and templet selection, 1-9, just move the templet around while recording is on and save as, when you play back it has saved the song as a templet/saved file...
just make sure to rename the file as you might know it will overwrite a spec file in a heartbeat...
i'm no where near tech enough for tony but i can make the badest ass loops and vsti with it...
excuse the dua factor...
HEY! we need a FL forum section, hey, anyone there? wake up knock, knock...
peace...
