Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 08-01-2003
jazzrich9 jazzrich9 is offline
Senior Member
jazzrich9 is on a distinguished road
mixer question, tech help?
so, I finally settled on a tascam m520, in almost perfect condition, except that the 8 buss outputs (xlr's) won't work. everything else about the board performs flawlessly right down to immaculate pots, even all the other outs are in top form, but the 8 main outs will not put out a signal.
If anyone has any idea of either what might be wrong, or how I could go about fixing it, I'd appreciate the advice, it seems very weird that all 8 would be completely dead.
Thanks in advance for any help you can offer.
Regards,
Rich
Radium Reactor
www.radiumreactor.com
Old 08-03-2003
Dom Franco's Avatar
Dom Franco Dom Franco is offline
Force of Nature
Dom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond reputeDom Franco has a reputation beyond repute
Read the manual....
There may be something very simple that you are not doing just right. Read the manual first, especially the section regarding channel assignments, pan control, master out section, pre-post eq fader etc.
Without the board to look at, I can't tell you much more than that but it would be highly unlikely that all 8 bus amplifiers are blown.
I'm guessing it is just a switch or patch cable needed to make it work.
Dom
Old 08-03-2003
jake-owa's Avatar
jake-owa jake-owa is offline
Banned
jake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud of
Hey Jazzrich, I have an M600. I wonder if the buss channels have inserts on them? If so do they need to be normalled to get signal across the cuircuts?
Just a thought.
Old 08-04-2003
Senior Member
Hi guys, thanks for the reply, I'm kind of in a holding pattern while I wait for the manual...
I think the answer will probably lie in the loads of pgm ins and outs on the back of the board that I don't quite understand... there is a pgm access section, that has jumpers on each of the send and receive channels... there is also a non descript 'pgm' section that has 1-8 as well as a pgm out with two rcas for each out 1-8
(I'm using these as my buss outs while I wait to fix the problem with the mains. As near as I can tell, they work the same as the buss outs, but removing the aux efx from the signal)
Jake, your suggestion sounds like it might involve those wiley little pgms in some way... do you have those on the 600?
Anyway, thanks for the help, I'll probably post again once I have the manual. If I still can't figure it out.
Thanks.
~Rich
Radium Reactor
Old 08-05-2003
jake-owa's Avatar
Banned
On the M600 you need to jump each send to a return by patchbay or direct cable or no sound goes anywhere.
