Old 07-30-2003
Henry Low Henry Low is offline
Junior Member
Henry Low is on a distinguished road
Hiss coming from cable?
Hi guys, well i have a Studio Projects B1 and a Behringer tube amp (mic100) connected to a Creative SB128 soundcard (yeah i know). I am getting a considerable amount of hiss from my recordings. I am currently using a 1/8 inch male plug cable to my computer with a 1/4inch converter connected to my preamp. Is the plug converter the thing that is contributing to all that hiss or is it mainly my soundcard? would getting a cable without a converter connecting my preamp to my soundcard recduce the hiss by alot?
THanks in advance
It's even more impossible if you don't try.
Old 07-30-2003
maestro_dmc's Avatar
maestro_dmc maestro_dmc is offline
Uses Paramedic EQ
maestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond reputemaestro_dmc has a reputation beyond repute
Do you hear the hiss while recording or on playback only?
I don't suspect the cable, and you shouldn't have a lot of hiss unless your signal chain is adding it, in which case you should hear it when you monitor during recording.
This is the first time I have heard of someone using that Behri Pre so far, so I don't know if it's extra noisy or not. I certainly plan to steer clear of it myself.
Try disengaging any pads both on the mic, and on the pre-amp.
Make sure the record in level (in the computer) is set to a decent level after you have disengaged any pads.
And get yourself an Audiophile already!
Or a 1010
Old 07-31-2003
Aren Aren is offline
Dedicated Member
Aren is on a distinguished road
Hmmmpf. Make sure that the pre-amp is connected to the line-in jack of the SB, and not the mic in. Its a common newbie mistake, and sometimes you just accidently mess up the wires.
This could cause a lost of hiss....
Old 08-01-2003
Junior Member
ahh thanks, ill try that.
