Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 07-30-2003
Phyl's Avatar
Phyl Phyl is offline
Master of the Obvious
Phyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to behold
Recording Shakers
I've had problems getting a good sound recording shakers. I've tried my Oktava MC12, Rode NT1, and Shure SM57. I've tried several different miking arrangements and still get this really brittle, rattle your teeth, fingernails on the chalkboard sound.
Eq helps somewhat but I feel like should be able to get a halfway decent sound before using it.
Any suggestions for mic choice, placement, eq, compression etc would be welcome.
BTW, I'm using the preamps in my Aardvark Q10. Here's the shaker:
http://www.musiciansbuddy.com/1/Drum...t-Shakers.html
Old 07-30-2003
kjam22's Avatar
kjam22 kjam22 is offline
Dedicated Member
kjam22 is on a distinguished road
I've recorded a shaker a couple of times. Once used a Studio Projects C1..... and the other used an ADk a51s. Thought both came out good, and was easy to do. But maybe I'm not particular enough about a good shaker sound. I put the mic on a stand all the way down. Sat in a chair in front of it so that the shaker was about a foot and a half away from the mic. I don't remember even adjusting the eq after I was done.
Have recorded tambourine the same way.
Old 07-30-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
A small-dia such as the AKG451, Shure SM81, or even an AT4041 would work quite well...
Those type of high-transient signals are particularly tough for mics to reproduce well (as demonstrated by the "jangly keys test")....
When you mic it, make sure it's in a good sounding room and back-off a bit -- don't get in too closely.
Old 07-30-2003
Phyl's Avatar
Bingo. I've been "shakin" about 6-12 inches from the mike, guess I'll back up a bit. I'm recording in my basement and haven't done any acoustic treatment to the walls, ceilings etc..
I've also noticed that the recorded waveform has a lot of very strong transients, making the attack portion of the waveform very pronounced.
