Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 07-25-2003
c-funk c-funk is offline
Newbie
c-funk is on a distinguished road
Stupid question about ancient gear
While I am not generally an idiot, MIDI is something I've totally ignored until recently. Sudddenly, I see how it could be useful, but I can't get it to work the way it's supposed to.
I have as a MIDI in/out a Soundblaster Live something something. Then, as my soundcard on my PC, I have the M-Audio Omni thingy. I have my YAMAHA DX7 plugged in with MIDI cables in and out to the soundblaster. If I play on the keyboard, it makes noise as expected. I guess it sends midi because the audio output is not hooked up. The problem is in getting multiple channels to play (with different sounds). The only thing I can get to work as far as playing a MIDI file is sending everything through channel 1.
I sent things out through "SB Live! MIDI Out (10C0)"
as other choices (none of which seem to work at all, I have
MIDI Mapper
Creative S/W Synth
A: SB Live! Midi Synth
B: SB Live! Midi Synth
Nemesys MidiOut: Port 1
Also, the DX7 needs to be turned on for any MIDI sound to happen at all.
Also, when I pick sounds through different channels, I don't get the standard MIDI sounds. If I pick sound #7, I get the DX7's sound #7, etc....
How do I make everything work like normal?
Old 07-25-2003
jake-owa's Avatar
jake-owa jake-owa is offline
Banned
jake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud of
Well you need to find out what soundbank you are playing. Which MIDI software are you using? YOu are not hearing the DX7 but your soundblaster card making noise on the keyboard's command? What are you trying to do? Do you have teh sounds you want on the Yamaha keyboard? Why not record audio out of the DX7's stereo outs?
It would help to know what your trying to do. Are you tying to record a realistic sounding piano in cubase? You are most likely playing the most basic MIDI soundset in the soundblaster's memory. It's nopt going to sound very good.
Do a search on this site for 'soundfonts'.
Old 07-26-2003
AlChuck's Avatar
AlChuck AlChuck is offline
Been Here, Posted That
AlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond repute
Very confusing question. Let's start with this bit...
If the DX-7's audio outs are not hooked to anything, then clearly you must be triggering one of the MIDI synths available on the SoundBlaster.
That should not be a problem at all with the SB Live. For each MIDI track in your software, have you selected a separate channel and is the destination device the A or B SB Live! MIDI Synth?
With the DX-7, that might not be multitimbral -- you might only be able to get one sound at a time out of it. But you said it's audio outs are not connected to anything, so that can't be your issue.
Well, duh... how do you expect it to send any MIDI messages if it's off?
Ok, here's where we really enter the Twilight Zone... you already said you only get sounds when you use Channel 1, now we have different channels? Perhaps you mean different patches or program numbers.
What "standard MIDI sounds" do you mean? I'm guessing the so-called General MIDI set, where program 0 (or 1, depending on the synth) = acoustic piano, program 35 (or 36) = fretless bass, etc. The DX-7 was made before the GM spec, it is not a GM-compliant synth, so its program numbers correspond to a different set of sounds. But wait. Your DX-7's audio outputs are not connected, you said... then you certainly cannot be getting the DX-7's sound from any patch.
So at this point all I can do is throw up my hands and say: we need more info, accurate info. The DX-7's audio output cannot be both hooked up and not hooked up.
That's the output port of the MIDI interface on the SB Live. That means you are trying to trigger an external device (the DX-7, I presume). But again we run smack into contradictory statements that you made.
Before bailing, let me point out a thing or two that might help you clarify what you are trying to do and why it might not be working for you.
As MIDI output devices (possible destinations for the MIDI data to be sent from your sequencer), you have this MIDI Out on the SB Live, plus the others you listed. Here's a description of what the others are.
Creative S/W Synth - this is a software synth that comes with the SB Live. It is not very useful because it responds to slowly to be used in realtime, and sounds pretty bad too. Its output would be heard through the SB Live's audio output if it's not disabled in the mixer utility for the soundcard.
A: SB Live! Midi Synth and B: SB Live! Midi Synth - the SB Live has two hardware-based synths, labeled A and B. These address sound sets in the computer's memory, which is how you can get different sound sets (called Sound Fonts) out of the SB Live's onboard synth. When you load a Sound Font instead of the default sound set, it shows up as Sound Font device or something like that instead if synths A and B. Their output would likewise be heard through the SB Live's audio output, if they're not disabled in the mixer utility for the soundcard.
Nemesys MidiOut: Port 1 -- I don't know what this is for sure, but Nemesys was the developer of Gigasampler, which is a software sample player... do you have one of their products too? But why would it be called MidiOut? Puzzling.
MIDI Mapper - this is a Microsoft utility on the computer that lets you define a MIDI mapping. It would be used to remap MIDI channels between the source and destination. Say you had a GM MIDI file, and wanted to play it using similar sounds on a non-GM synth. You could change all the patch numbers in your file's tracks. but then you have to do that again to get it back the way it was before. With a MIDI mapping, you could reassign where Channel 1's data from the sequencer actually gets sent. Then you can always use this map instead of changing sequencer channel assignments back and forth. Much more sensible, especially if you are going to use this combination of hardware and software a lot. But most people don't use this much, and you would have to understand it and have set it up to get anything out of it, so I'd ignore it for now.
Old 07-26-2003
James Argo's Avatar
James Argo James Argo is offline
Fancy Rock N' Roll
James Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond repute
Smile
Alchuck explained it pretty well
I got the Yamaha DX7 several years ago. Sold for ~$200, replaced with Korg. I don't remember many thing about it, but it's way to complicated to match nowday's needs. What I thought is indeed, it's super synth on it' time, but Yamaha faild to provide sufficient documentation and user friendly interface. In simple words, it's absolutely not for beginer at all !!! Time has changed, I think you better learn MIDI with at least General MIDI (GM) concept as basic requirement first, then you might find answers for your problem. Oh, BTW I believe you need the Grey Matter Response's E upgrade kit to bolsters the the program tally to 320, and improve the MIDI implementation such Local On/Off, full 16 channels access, and wide ranging MIDI filtering. You probably will need to give us more hints like Alchuck mentioned to (probably) get better infos.
Jaymz
Keep Rockin' and Rollin'...
Old 07-26-2003
Newbie
Thank you for such detailed responses to my poorly-phrased problems. Since so many things don't work, it is hard to describe. I am definitively getting Yamaha DX-7 sounds when I play MIDI files, e.g. in Sonar. I can get any one sound from the DX-7. (Oh, the audio output is hooked up, I'm sorry. It's hooked up in the back of my Omni studio so I forgot about it. I am turning out to be a bigger idiot than I gave myself credit for!) To get any sound whatsoever, I have to set the output device to the SB Live Midi Out, and the channel to 1. I can pick a patch, and I will get a DX7 sound for that track of the midi file. If I set another track to channel 1 also, both parts will sound (with the same patch). If I change the patch on the second track, both tracks will play with the sound of the second track.
What I would like to do really is get MIDI input from the keyboard (which I successfully do), but use some sort of software synth for the output. If I didn't own a keyboard at all, couldn't I somehow hear MIDI? But nothing else will make noise that I can figure out.
Old 07-26-2003
jake-owa's Avatar
Banned
If you do not have the audio outputs hooked to the computer's line in there is no way you are hearing the DX7's sounds. You can't hear MIDI. You need to do a search on MIDI basics...use the search! When you change programs on the DX7 you are sending MIDI program change messages to the soundblaster. The sounds may be similar due to a similar soundset but trust me MIDI is only triggering your soundcard's samplebank. Only audio wires will send the actual sound of the DX7 to the soundcard.
Old 07-26-2003
jake-owa's Avatar
Banned
http://www.homerecording.com/bbs/sea...der=descending
Old 07-29-2003
Newbie
So I managed to use a virtual synth. This is pretty exciting. Sonar lets me map all the outs to a DXi synth after I create it, then I can send the outs of the synth to the soundcard and I finally hear everything as intended. So at least in Sonar, I have a solution.
