Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 07-25-2003
Raydio's Avatar
Raydio Raydio is offline
Dedicated Member
Raydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond repute
Triton Transposing!!!!
Im in the Sequencer mode. I have a melody recorded to track 1. I would like to know a quick way to transpose the melody to another octave besides using Event Edit and going note by note. This is time consuming!!! Anyone?? Thank you!
Old 07-25-2003
stray411's Avatar
stray411 stray411 is offline
1K Silver Member
stray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond reputestray411 has a reputation beyond repute
The third Q&A down gives you the procedure. BTW, for 1 octave you'll need to transpose +/- 12 semis.
Found using www.Google.com.
http://www.jam-ind.com/KorgCanada/do...itonSeries.pdf
Stray
Old 08-03-2003
Jblount's Avatar
Jblount Jblount is offline
For the love of Drums
Location: Behind The Drum Kit Looking Out At The Meaning Of Life
Jblount is on a distinguished road
You cant use the global setting, there is a transposing mode isnt there?
Old 08-05-2003
bsanfordnyc's Avatar
bsanfordnyc bsanfordnyc is offline
Dedicated Member
bsanfordnyc has a reputation beyond reputebsanfordnyc has a reputation beyond reputebsanfordnyc has a reputation beyond reputebsanfordnyc has a reputation beyond reputebsanfordnyc has a reputation beyond reputebsanfordnyc has a reputation beyond reputebsanfordnyc has a reputation beyond reputebsanfordnyc has a reputation beyond reputebsanfordnyc has a reputation beyond reputebsanfordnyc has a reputation beyond reputebsanfordnyc has a reputation beyond repute
An extremely quick way to do this would be the following:
Whichever program you used in the melody in track 1, switch to program mode and go to that exact program. Then, under Performance Editor towards the bottom of the screen, just move the octave dial whichever way you want to go. If you switch back to SEQ mode, your track will play in accordance with the octave change you made.
Hope this helps.
That's just how I roll...
Old 08-06-2003
Raydio's Avatar
Dedicated Member
But what about using the pitch shift or detune effect in the "insert effects" menu. Shouldn't it transpose also?
Old 08-13-2003
Musikman777 Musikman777 is offline
Newbie
Musikman777 is on a distinguished road
Hi
I'm assuming you have a Triton Studio? (probably the same on any Triton) The easiest and fastest way to transpose an individual track is to go to Menu/Track Parameters/Pitch Tab. There you can adjust the pitch up or down in semitones for each individual track. You can do this while you are still in Sequencer Mode! Hope this helps!
Musikman777
Old 08-13-2003
Raydio's Avatar
Dedicated Member
Ok I see this works but what about half Tranposing/Detuning? Is there a way I can transpose or detune an instrument, but still have some of the original sound come out. Kind of like 50% flat and 50% detuned? I know you can just have two separate tracks but is this possible with one?
