Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 07-22-2003
amt7565 amt7565 is offline
Force of Nature
amt7565 is on a distinguished road
Question MOTIF drum pattern triggered from SONAR
Folks,
I find better support here than the Motif-forum. So here I am again.
The built in MOTIF drum patterns are awesome. Any idea if I can trigger these off my SONAR sequencer? Is it possible at all? I have checked the manual with no luck.
Thanks in advance!
Old 07-22-2003
Teacher's Avatar
Teacher Teacher is offline
do unto others......
Teacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond repute
if the motif is anything like the KARMA..no, u have to record it via audio...
"...if the opposite of pro is a con lets go beyond this, the opposite of CONgress must be PROgress..." Cage
Old 07-23-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Aren't they just triggered by a 'Note On'? If so then just have the Motif clock synced to Sonar and send it a note.
With the Karma and other apreggiator type synths you can trigger then externally but often you can't have the synth patterns trigger other synths.
Old 07-23-2003
Force of Nature
Thanks Guys!
Here is a question:
Lets say I like a particular drum pattern on the MOTIF. Is there away I can downlaod that pattern in .midi format from MOTIF, so that I can open it in SONAR and still play it in MIDI format?
Thanks!
Old 07-24-2003
enTRAP enTRAP is offline
Newbie
enTRAP is on a distinguished road
Arm a midi track to record and try it.
enTRAP
IVS Entertainment
Old 07-27-2003
James Argo's Avatar
James Argo James Argo is offline
Fancy Rock N' Roll
James Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond repute
That's right I dunno, I don't have MOTIF, but I have Korg N364, which can play petterns. Hook the MIDI out of the keyboard to PC's MIDI in, arm some MIDI track in SONAR, record while you play the keyboards pattern. The MIDI data will be recorded by SONAR... Have a try...
Jaymz
Keep Rockin' and Rollin'...
Old 07-27-2003
Force of Nature
Cool
OK guys, I will give it a try tomorrow. I hear that the MOTIF rack supports this function but not MOTIF6,7.,8.
Thanks for the help! Will keep you posted .
Old 07-28-2003
jiffy feet jiffy feet is offline
Newbie
jiffy feet is on a distinguished road
You could save the Motif pattern as a MIDI file and just open it up in SONAR. Provided you have a SmartMedia card reader.
Old 07-28-2003
Force of Nature
OK guys it works now!
I set:
1. MOTIF in 'pattern' mode
2. selected "patch" and chose a drum preset.
3. hit the "play" button on the MOTIF. Now MOTIF plays pattern.
4. Armed the SONAR MIDI track (Note: SONAR MIDI ch=10, IN ch=1, OUT ch=MOTIF1)
Midi data was beautifully sent to SONAR. Now I can replay back from SONAR.
To synchronize timing I can open the MOTIF .template file from SONAR and control SONAR start time by hitting the 'play' button on the MOTIF. For this to work both the template file and my program have to be open at the same time.
I like the SONAR built in user patterns because they sound more realistic than what I can program. It also teaches me how to program drum patterns better.
I can also uses Jiff's advise to use smart media card.
One problem I have, the metronome from the MOTIF also gets recorded. Does anyone know how to turn it off?
Thanks for the help.
Old 07-28-2003
Newbie
You have to turn the metronome off in Utility. I am at work right now so I can't tell you exactly how without seeing my Mo. It shouldn't be too difficult, though, and I am certain you could find that info in the manual.
If you are only talking about a MIDI file, thoug, coulldn't you just as easily go in and erase all the metronome notes?
Old 07-30-2003
Force of Nature
I just noticed that the metronome did not get recorded. However I am still unable to turn the bloody thing down in MOTIF.
Thanks!
