Go Back   Home Recording > General Discussions > DJ & Hip Hop Production
Reply    Audiofanzine Dj Dj News Dj Medias Dj Tests Dj Articles Dj User Reviews Dj Classifieds Ads
Old 07-16-2003
Flip Flip is offline
Newbie
Flip is on a distinguished road
Panning Beats?
In a feeble attempt to make my beats sound better i always try to use some panning, but it generally gets fucked up bigtime...
So I was wondering how you do it, which instruments do you pan? how much? and do you change the panning during the song?
Old 07-16-2003
questien questien is offline
Crossed Up...
questien is on a distinguished road
I usually try to pan the snare just a lil to the right, but still in the middle. The HH usually to the left but still in the middle. The main melody sits in the middle as well as the bassline, however filler instruments and sound effects i pan to the left or right.
Your name is aimless, and your style is pointless like "Undercover Police" tees...
Old 07-17-2003
Teacher's Avatar
Teacher Teacher is offline
do unto others......
Teacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond repute
the main melody i usually pan hard left and hard right...this gives space for the vocal to cut thru as well as giving the entire track a 'wider' feel...thats pretty much all the pannin i do unless its a weird efx that comes in once and a while i'll pan have it panning left to right(automation)...hi hat pannin is interesting too..just started getting into that...
"...if the opposite of pro is a con lets go beyond this, the opposite of CONgress must be PROgress..." Cage
Old 07-17-2003
beat amateur beat amateur is offline
Newbie
beat amateur is on a distinguished road
Could you be more specific about what 'fucked up' means? It just doesn't sound good? I'm quite a novice, but find myself using a new panning setup for each track. Some things obviously work better than others, of course...
Old 07-17-2003
eeldip's Avatar
eeldip eeldip is offline
Force of Nature
eeldip has a reputation beyond reputeeeldip has a reputation beyond reputeeeldip has a reputation beyond reputeeeldip has a reputation beyond reputeeeldip has a reputation beyond reputeeeldip has a reputation beyond reputeeeldip has a reputation beyond reputeeeldip has a reputation beyond reputeeeldip has a reputation beyond reputeeeldip has a reputation beyond reputeeeldip has a reputation beyond repute
you should try that timbaland thing and pan some shakers hard, alternating LR on 16th and 32nd notes.
generally panning kick and snare sounds a little weird. but it can be done. if you do it, you are going to make your beats sound "experimental".
sending little plinky things left and right is pretty normal though if you want to make mainstream beats.
some other thoughts:
leave an instrument in the center, but pan the reverb or other effect.
ping pong delay, or auto pans are also cool.
playing with phase and panning is dangerous ground, but usually yeilds some cool effects- like put a 2 delays on a snare, with slightly different timing, both 180 out of phase from one another. dangerous cause if people listen to the music in mono all sorts of strange things happen.
very truly yours,
hugs and kisses,
george.
Old 07-18-2003
L'espion Noir L'espion Noir is offline
Force of Nature
L'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond repute
the Black Spy Schematics
i like panning (when i do) by the pitch
like the bass and the kick at 2 and 10 o'clock
i usually use a combo of snares (lil secret, pay me later)
- the main snare 12 noon
- and the other two not further than 9 and 3 o'clock
i might couple the high hat with a string and pan them, not hard but somewhere close to 5 and 7 o'clock
the melody always run at 12 (center)
PS: i'm combining snares because i'm using Battery which allows me to manipulate each cell (sound) separately , so i can layer sounds without OD'ing
