i just bought a sp b1
it's my first condenser.. so i might be making a mistake..
but is there supposed to be distortion when i sing loud? if i listen to my vocal track, there's some reverb (probably from my untreated walls) and distortion when i sing out loud.. i'm gonna do something about the reverb thing soon, but is there supposed to be distortion? please help me guys i'm a student and i'm poor and i'm scared |
Re: i just bought a sp b1
Are your sure it's the Studio Projects B1 mic distorting and not something else in your audio chain instead? If it is the B1... and sense the mic is new, I'd just return it to whoever you bought it from and ask them for a new one that works. |
How close are you standing to your mic.
I seriously doubt you are clipping a B-1 with vocals. Please describe everything this mic is plugged into, 'cause it sounds like you're clipping *something*.-Richie
i've got an audiophil 24/96 with a berhinger mixer
the b1 is connected to the mixer.. and i know some of you are gonna say that it's the mixer, but i had no problems when i had an sm58 on it.. so should i return the mic?? |
Unless there is some issue with the phantom power supply.
If you feel the need, take the mic back........BUT get the store to try it out WHILE YOU ARE THERE. Show them EXACTLY how it plays up on your voice..............if it still is dodgey in the store, then at least you know it was the mic, and they have heard what it is doing. ![]() |
thanks.. but..
i bought it from an internet site.. thanks though |
Don't return the mic until you are sure there's something wrong with it. I think DJL's way jumping the gun here. The B-1 produces a much hotter signal than an SM57, and the pres in a Behringer mixer are easy to clip. Turn the channel volume down, and back off from this mic a bit. You can use an SM57 anywhere from 8" to swallowing it. With a condenser, try 8-12" and turn the channel gain down. If you try to use a condenser mic as if it were a dynamic, you can clip anything, especially a Behringer mixer. Lots of things sound like crap when you don't know how to use them. Have you got a pop filter in front of this mic? You may not need one with an SM57, but you absolutely will with a condenser. This is a whole different animal, and I'm betting there's nothing wrong with this mic except you don't know how to use it yet.-Richie
Iv'e got pretty much the same setup as you, delat 2496, b1, sm57 behringer mixer. I have to set the gain pretty low on the channel compared to the 57.
#12
#13
doug h
doug h..
does your b1 clip too? i hope it's because i put the gain up too high.. lemme go try it. |
#14
A rock singer who's very loud can produce more than 150 dB at a distance of one or two inch.
That's way to loud for a B1 and for a Neumann as well. A dynamic mic has kind of a "built in limiter" and can handle more SPL (sound pressure level) than most condensers. If you are not a very loud singer and you use a distance of a feet from the mic, it shouldn't distort at all. Turn your gain to it's minimum and let us know what happens. |
#15
#16
ah!!!
39 dollars?!
i tried with the gain and the volume.. and.. my conclusion is.. that it's no good.. if i turn down the gain, it sounds like the vocal's buried in the music, and when i raise the volume on my cooledit to where it's tolerable, i get that same distortion again.. i Am singing loud on the high parts.. so maybe i'm singing too loud?? is that possible? (the distance was somewhere around 10~12 inches as someone in this thread told me..) soooooo i guess i'll wait and try out some more things for the next few days and it that doesn't work, i'll have to return it.. |
#17
Compression? Limiting?
#18
#19
Re: ah!!!
#20
i'm hoping it's a user error..
but i think it's a screwed up mic.. (on another note, why's the mic clip so lose? it keeps falling down) |
#21
#22
Yes Please contact us at the Link Chesrock posted
If you feel it is a faulty mic, Call us up we will ATR the mic, fix what ever problm's you feel it has and return it to you.
I will one day come up with a good Mic Design like my mentor Brent |
#23
do you mean chessparov?
chessrock gave me a link to a shopping site.. what's ATR, and how should i explain about the mic since i bought it from somewhere else? oh, and by the way.. thanks a lot everyone have a melliflous day-! |
#24
Oh yea ChessProv
Did not read thred threw, just glanced, Just call us up. Explain what is wrong with the mic. We will give you a ATR# you will send us the Mic with return address. Then we will look over the mic and test it make shure it works perfectly and send it back. Just give us a call we will get it taken care of
#25
Got a droopy B1 mic clip?
http://www.studioprojectsusa.com/pdf...justment_c.pdf |
