Old 07-03-2003
mbuster's Avatar
mbuster mbuster is offline
Sandwich
mbuster is on a distinguished road
Monitor Isolation
I saw advertised a set of monitor isolation pads, which are supposed to eliminate resonances in whatever they happen to be sitting on, thereby lessening coloration. Is this a gimmick or a lgitimitely useful product? Can some block foam, or neoprene or something serve the same purpose? Thanks.
Old 07-03-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Re: Monitor Isolation
It's lgit.
Yep.
You want to use a material that will dampen or isolate vibrations going from the monitor to the stand/desk.
Old 07-06-2003
frederic's Avatar
frederic frederic is offline
frederic.midimonkey.com
frederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond repute
Tex is right, any foam or neoprene works fine. In a real pinch, thick placemats even work.
The key is to isolate the vibrations of the monitors cabinet and whatever it is sitting on; stand, shelf, pole, cables.
Old 07-06-2003
mbuster's Avatar
Sandwich
Thanks, fellas. I'm gonna give it a shot.
