Old 06-30-2003
Munchkin Munchkin is offline
Newbie
Munchkin is on a distinguished road
Aux Bus
Anybody got any nuggets of information, any tips and tricks, any techniques for using the Aux Bus to put reverb effects on a mix. Any special considerations as far as the Pre or Post Fader Enable switches?
Anything to warn about, what not to do?
Old 06-30-2003
A1A2's Avatar
A1A2 A1A2 is offline
1K Silver Member
A1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond reputeA1A2 has a reputation beyond repute
my 2 cents
here is what I do:
set the verb plug-in to 100% wet (no dry signal) and then blend it in by adjusting the Aux send level on the track, and I usually pan the aux return a little if the track is not stereo, or needs to sound wider.
I dunno about the pre vs post tho, I use pre if the gain of the track is being turned down alot, but I really could be wrong on this.
Lastly, save your CPU by using as few reverb plug-ins as possible. I normally have about 2 reverbs on the auxes, so when 2 instruments are playing at thesame time, I have 2 different verbs for them instead of running everything that's playing at the same time thru the same reverb.
Al
Old 06-30-2003
moskus's Avatar
moskus moskus is offline
The Creator of Æ, Ø and Å
moskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond repute
I usually use two reverbs too, on aux A and B. One reverb set to a long (large) decay-time, and the other to a short decay-time. Then I feel I can better place the instruments in a mix...
Two wrongs don't make a right, but two Wrights once made an airplane...
Old 06-30-2003
crosstudio's Avatar
crosstudio crosstudio is offline
Reggae + Go-Go = Regg'go
crosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond repute
when i upgrade my PC i'll try using 2 reverbs. i usually use 1 reverb and 2 delays. i normally only put a small delay on the lead vocal (and put that same delay on lead guitar or midi generated horns).
i use post instead of pre so that my reverb send stays in balance with the track if i change the volume of the track.
Old 06-30-2003
Newbie
This may be a stupid question but, what are the advantages/disadvantages of each setting...Pre and Post fader? Could you elaborate more on that?
I've done some tests with mixing down the mix to two track stereo and running some gentle compression on it to get an idea how it will sound when mastered. I find that there is more reverb present that way than with just the basic mix. (Did that make any sense?)
And thanks everybody, for your input!
Old 06-30-2003
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
The "pre" and "post" refers to the Track fader - i.e., pre-fader vs post-fader. As Cross indicated, if you want the aux bus to follow your track volume, you need to set it post fader - otherwise your wet/dry balance will change with any changes in the track volume.
I always use post fader, since I haven't yet figured out a use for the "pre-fader" setting. I imagine one exists, but I have yet to run across a need for it.
Old 07-01-2003
Newbie
Well...This changes everything!
Thanks everybody
Old 07-01-2003
ChorazaiM ChorazaiM is offline
Junior Member
ChorazaiM is on a distinguished road
Interesting. And you would send the signals that you want to sound more upfront in the mix to the short decay, while sending the rest to the other, or do you route the signal through both and adjust the amount of each?
Old 07-01-2003
moskus's Avatar
Well... hmm... I can't give you any clear guidance here. I just control the send volume till I got the sound I want and where I want it...
A little of both suggestions, I think.
Old 07-01-2003
Strryder Strryder is offline
Force of Nature
Strryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond repute
One of the ways I use the "pre" fader setting for an aux send would be if I had a track that I wanted to be pretty low in the mix, like maybe shakers, but want a stronger reverb on them, I can just turn up the aux send.
