Old 06-22-2003
bigmedia bigmedia is offline
Newbie
bigmedia is on a distinguished road
Newbie help needed with MIDI
I have recorded a MIDI track into cakewalk Pro Audio 9.03 from a keyboard. When I play it back, the sound comes out of the keyboard, and not my computer. How do I get this to play as a track on my computer? Thanks.
Old 06-22-2003
James Argo's Avatar
James Argo James Argo is offline
Fancy Rock N' Roll
James Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond repute
Lightbulb
Usualy, there will be reply within minutes here But this is weekend, and everybody seems to have their time off (except me, off course ) so just be patient a while
You don't have to post two thread asking same question here (cross post) it's dissliked by most members here They'll be there while have a chance
ps. and Welcome to the Board, bigmedia
Jaymz
Keep Rockin' and Rollin'...
Old 06-22-2003
Porter's Avatar
Porter Porter is offline
aka WookieMan
Porter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud of
bigmedia,
What sound card are you using? Some come with the ability to play MIDI sounds, like the Creative series. It sounds like you have the 'out' set to the Cards MIDI out, not to the onboard MIDI Synth.
Porter
Old 06-22-2003
Newbie
It is an e-machine computer with its original sound card and MIDI controller. I previously had this working where the MIDI was recorded through the MIDI connection. I am not sure what you mean by I may "have the 'out' set to the Cards MIDI out, not to the onboard MIDI Synth". Thanks.
Old 06-22-2003
Porter's Avatar
aka WookieMan
Depending on your Sound Card... some have an on board Synthesiser which will play the MIDI notes as audio, instead of sending 0's and 1's to an external MIDI device to play the sounds.
Porter
Old 06-23-2003
moskus's Avatar
moskus moskus is offline
The Creator of Æ, Ø and Å
moskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond repute
So basically what Porter means is that if you check Options -> MIDI Devices you'll see one device in the input section and 1 or 2 in the output section.
If you have 1 output, then your soundcard doesen't have an onboard synth. And if you have 2 outputs it probably does.
And basic MIDI let's only data go through the cables. You should hear the keyboard play, not your computer. If you want that, you can either use the sucky synth on the soundcard (if present), or only record it to disk using a audiocable connected to your synth and soundcard.
Two wrongs don't make a right, but two Wrights once made an airplane...
Old 06-23-2003
Qwerty's Avatar
Qwerty Qwerty is offline
1K Silver Member
Qwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond repute
Yeah - what he said.............
Tell us what you expect or want
Tell us what your hardware is - OPTIONS-MIDI and OPTIONS-AUDIO
What the other posts mean is -
1. What track is ur MIDI recorded on?
2. Look on the left hand side of the screen
3. What is the "OUT" listed as 'pointing' to?
4. Change this to route your recorded MIDI data to a different thing
Cya,
Q.
<insert something witty here>
