Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 06-21-2003
jake-owa's Avatar
jake-owa jake-owa is offline
Banned
jake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud of
Anyone know anything about MIDI electronics?
I'm thinking of making a kick pedal with its own note programmable MIDI out. It would need to be velocity sensitive and use the standard MIDI protocol.
Anyone?
Old 06-21-2003
James Argo's Avatar
James Argo James Argo is offline
Fancy Rock N' Roll
James Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond repute
Thumbs up
Whew, that's a homerecer's spirit, jake
I dunno, IMHO, I'd rather go with pad triggering device a bit more expensive, but save me alot of time for actually makin' music instead of headache thinkin' the circuits
Jaymz
Keep Rockin' and Rollin'...
Old 06-21-2003
Roel's Avatar
Roel Roel is offline
That SMART guy.
Roel is on a distinguished road
I know it. Used to know half the protocol by heart.
What you need to do is figure out a way to convert the physical action to some sort of electronical signal. This means, some sort of circuit that detects whenever the kick is hit, and some sort of signal that is in relation to the velocity of the hit.
From there on the circuitry is easy and straight forward. The midi protocol is an easy historical protocol that can be handled by the most simple microcontrollers. You program it to receive the hit-signal, measure the velocity, and then send out the note on message. And the note off message right afterwards probably. (I don't really know the details about how note off is handled by these kind of controllers.) It's really easy to program that.
The hard part is the velocity really. I haven't got a clue how that is done. I know you can easily make this kindof pad by putting one of those piezo-speakers (that also function as a mic) under some rubber. Don't know how they handle velocity, could be that you can just measure the output of the mic. (Easily done by the builton ADC's of a microcontroller.)
The hardest part in making these pads, as some drummer once told me, is finding the right amount of rubber etc, to get a good physical response of the 'drum'....
Old 06-21-2003
duck's Avatar
duck duck is offline
Dedicated Member
duck is on a distinguished road
I can only give you some Info Links if that helps Jake.
bottom of page.
http://www.epanorama.net/links/music.html#midi
http://www.troikaranch.org/geekpage.html
What!
Old 06-21-2003
jake-owa's Avatar
Banned
Thanks guys, I'll keep ya posted on the progress...if there is any.
Old 06-22-2003
jake-owa's Avatar
Banned
I think I'm just going to try to cannibalize a keboard velocity pad and mechanism and try to adapt it to a pedal.
Old 06-22-2003
Roel's Avatar
That SMART guy.
That would be rather hard. A kick pedal can be quite aggressive when compared to a key.
Also, the way velocity of a keyboard works is done with 2 sensors. One triggers just before the other one when you push down the key. The difference in time between the 2 sensors being triggered is in direct relation to the speed you push the key, and thus the velocity.
With a kick, normally you really have just pedal hitting a fake drum which contains the sensor. Here it is really measured how hard it is hit.
If you look around, you'll find a link to making drumpads somewhere. Those piece-speakers they use can be bought deadcheap.
Btw, have you ever programmed a microcontroller or designed any electronic circuitry? If not, you are in for one hell of a fun ride.
Old 06-22-2003
Roel's Avatar
That SMART guy.
HERE is some more info for ya...
THIS one gives you a good idea of how the triggers are constructed...
Whenever you wanna make something yourself, the keyword on the internet is DIY...
Old 06-22-2003
Roel's Avatar
That SMART guy.
Here's about everything you need to know for the electronics in it... http://tomscarff.tripod.com/8way_drm2/8way_drm2_1.htm
The only thing you gotta figure out yourself is programming the microcontroller!
Old 06-22-2003
James Argo's Avatar
Fancy Rock N' Roll
Thumbs up Roel...
This SMART guy deffinitelly knows what he's talking about Nice links, Roel. Learning something new everyday
Jaymz
Old 06-22-2003
jake-owa's Avatar
Banned
Thanks Roel, no I haven't done to much elecrtical engineering but I was hoping I could adapt the key thing and MIDI out from a keyboard. I guess the leverage of how the key is struck could be adjusted but it might be more trouble than it's worth. No, I 've never done any PIC programming or assembly language but I was hoping to find an easier way, maybe partially preassembled parts.
Thanks for the links.
I wish I could just find someting to buy but there IS nothing like this. Plenty of pedal triggers but none with a MIDI out.
  #12
Old 06-22-2003
Roel's Avatar
That SMART guy.
Well, that last link I gave you leads to a place that sells kit for that component. But if you look around, you might be able to find one of them older digital drum modules that do this conversion, but also have samples in it... Don't know the prices, but it's been there for way long time, and there's alot of new stuff around so the prices are probaby reasonable.
  #13
Old 06-25-2003
zekthedeadcow zekthedeadcow is offline
Dedicated Member
zekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond repute
those links rocked... here's one I found for a midi console controller that I want to try.
http://www.ucapps.de/
  #14
Old 06-25-2003
Leeking's Avatar
Leeking Leeking is offline
TrueVine Studio
Leeking will become famous soon enough
yeah, I was seriously considering that, but ended up getting one in ebay.
Leeking
My songs
My studio pics
  #15
Old 06-25-2003
Leeking's Avatar
TrueVine Studio
Re: Anyone know anything about MIDI electronics?
Anyone?
Jake, if you already have a drum module, this would be pretty simple. If not, get one!!!
Leeking
My songs
My studio pics
  #16
Old 07-05-2003
Fela Fela is offline
PHD of Phrenology
Fela is on a distinguished road
I made a drum set out of piezo buzzers, tractor innertubes, particle board, PVC pipe and an alesis d4 brain. D4s go for about 100 bucks or less now. Radio shack makes some piezo buzzers that are just a diaphragm with a thin piece of plastic around the edge, they are bigger and work better. Just plug those into a drum brain with a 2 conductor cable and let it rip. Generally, drum triggers don't send a note off message.
If I still have that drum set it may be fer sale.
  #17
Old 07-06-2003
jake-owa's Avatar
Banned
Which drumset, how much and would you consider a trade?
  #18
Old 07-07-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
I have to agree with Felo. I would think using a Piezo trigger and a real kick pedal would be the way to go. You still need an electronic head to accept the triggers but building that would be pretty intense IMO. The trick is converting the analog signal to midi and that requires some type of IC. I would look for a used D4.
  #19
Old 07-07-2003
jake-owa's Avatar
Banned
I would but I can't stand Alesis drum sounds. I'm looking into a used Yamaha module right now for $150.
  #20
Old 07-07-2003
Audio Bum
You don't have to use the Alesis sounds. You can midi out from there to any module. If that Yammi has trigger inputs then you're all set.
  #21
Old 07-07-2003
jake-owa's Avatar
Banned
Yeah Tex, it has trigger inputs and 8 audio outs so I think I'm in business.
  #22
Old 07-08-2003
Audio Bum
Whats the model of the Yamaha? I'd like to get a trigger head one of these days and the Alesis is the only cheapie that I'm aware of.
PS- I finally pulled the cables from my rig and got them packed up. Hopefully ship in a day or so.
