Old 06-10-2003
Bigus Dickus Bigus Dickus is offline
Dedicated Member
Bigus Dickus is on a distinguished road
In-wall rated mic cables
Are typical mic cables that might be ordered on-line or purchased from a local music or guitar store compliant with building codes for in-wall use? If not, what do you guys suggest for lengthy (100') runs of in-wall cable? Is DIY an option?
Old 06-10-2003
Fletcher's Avatar
Fletcher Fletcher is offline
Force of Nature
Fletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond repute
Re: In-wall rated mic cables
DIY is definitely an option here.
There are no building codes I'm aware of that are applicable to mic lines as they're carrying such minimal voltages that you could, for all intents and purposes, stick them up your ass without fear for your safety... they carry less voltage than the wiring necessary for your alarm system, so what's more of a priortiy are the RF rejectin properties of the wire, it's overall phase response, and lack of capacitance over long distances.
If you have an old Fender guitar amplifier and a Stratocaster [basically anything with single coil pickups] that doesn't get radioi stations... then I'd probably recommend something like a Mogami kind of cable... if you get a radio station [TV station, etc.] in the guitar amp combination... then I'd recommend that you go with some kind of "Star Quad" design [I generally recommend the Canare version... but from what I understand the Mogami version will do about as well].
To "DIY" this kind of operation you will need to have soldering chops. I would also highly recommend that you put in more lines than you would ever think you'll need as you can never really anticipate how your facility might grow, nor can you fully anticipate what you requirements may be 5-10-15 years from now [and if you're talking about running these lines through walls, you're talking about them being there for quite a while].
The other recommendation I would make is that when you do this... order about 15-20 feet more wire than you think you'll need and leave it either in the wall or in the floor so in case you move things around later in the life of the room... you'll have wire for whatever may happen. I know several places where if they had just left an extra 15 feet of wire kicking around when they changed from a desk with a right hand onboard patchbay to a desk with a left hand outboard patchbay they would have been able to accomodate the new desk with the old wires... instead of having to rewire the whole facility from top to bottom.
Best of luck with it.
Fletcher
Mercenary Audio
mwagener wrote on Sat, 11 September 2004 14:33
We are selling emotions, there are no emotions in a grid
Old 06-10-2003
Dedicated Member
Thanks for the tips.
I think the "code" has more to do with fire retardation or transmission of the insultation so that fire can't be spread as easily through wall barriers in homes, and less to do with protecting the wall from the wire in case of wire short or other failure.
Thus... I guess what I need to know is if typical Canare or Mogami cable has the correct UL insulation rating.
This isn't for a studio actually, but a new house I'm having built. I want a pair of mic outlets in the formal living area of the house so that it is convinient to record my grand piano when I choose, without having to have all the equipment set up in close proximity.
Old 06-10-2003
acorec's Avatar
acorec acorec is offline
Banned
acorec has a spectacular aura aboutacorec has a spectacular aura aboutacorec has a spectacular aura about
If you are serious about it, you should install 3" conduit so you can pull cable thruogh it. This will allow you to add in the future. Also, you should think about installing your own isolated grounding system that routes to the outside to a iron post in the ground. These are real studio tricks that will pay big dividends in the end.
Good Luck!
