Old 06-10-2003
billisa billisa is offline
1K Silver Member
billisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond repute
VF-80 -- a buzzy noise...
I was halfway into a session last night when I noticed a buzz start happening as I was sitting, waiting to record a track. It just started as I was sitting there... When the record was in stand-by mode, the buzz would raise/lower slightly as the red record light flashed. It would go off if I disarmed the track.
As I say it just appeared as I was sitting, waiting, with a track already armed for a few minutes. So i know exactly when it started. Fiddling with wires didn't help.
HOWEVER, when I shut everything down, I went downstairs to find a fluorescent light in my kitchen was buzzing alot (never did this before). Could this cause interference on my VF80?
Old 06-10-2003
bdbdbuck's Avatar
bdbdbuck bdbdbuck is offline
1K Silver Member
bdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond repute
Were you listening through cans? I know the MR8's sometimes have that in the headphones circuitry, all you have to do is turn it off and then on again and it usually fixes the problem.
bd
Old 06-10-2003
bdbdbucksKID's Avatar
bdbdbucksKID bdbdbucksKID is offline
Senior Member
bdbdbucksKID is on a distinguished road
Buzzing
The light might be a factor...also, check your power. If there is an inconsistancy with the power...that also may be a problem.
Static electricity or any other electrical appliance can cause the buzz. If you are too close to the power source, if the instrument is too close to the unit (you'll see this with amps alot)...it's similar to feed back. I have even noticed a buzz clip with my condenser mic. (it uses phantom power) Oh also, speakers and computers can contribute to it if the unit is too close) I have had my experience with power flux and interference by trial and error.
It might also be wise to invest in an UPS (back-up battery and surge protector)....this will protect against brown-outs/black outs and powersurges that will eventually protect against hard drive surface problems. You'll thank me in the end.
If you live in a Townhome or apartment, I especially recommend it. Who knows....it could be coming from a neighbor blowdrying his backhair. Anyway...hope this helps.
BTW....change that bulb!
Old 06-10-2003
dave in toledo's Avatar
dave in toledo dave in toledo is offline
Force of Nature
dave in toledo is on a distinguished road
buzz
flouresent tubes and neon can cause a buzz in my pa system i dont see why not with a recorder, but you would have to be pluged into the same breaker as the flouresent, im pretty sure.....
Old 06-10-2003
Garry Sharp's Avatar
Garry Sharp Garry Sharp is offline
Lost Cause
Garry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond repute
Weird buzzes that come and go, eh? Could be all that electrical stuff....but then again it's most likely you've got a ghost. We have a poltergeist who visits sometimes. Any violent deaths in your house you know about?
Old 06-10-2003
1K Silver Member
Fixed it...
I had one too many wires hooked up between the keyboard I was using and a preamp I'd been using before... Once I unplugged the extra connection, no buzz... But I will still look into violent deaths... Always good to keep up on these things, and I've been a bit remiss on this.
Old 06-10-2003
Lost Cause
Ah, yes, it suddenly stopped because you unplugged a bit of wire. This can only mean one thing. Not only do you have a ghost but he's a highly intelligent one who's watching you all the time. Lulling you into a false sense of security.
Every time you turn the machine on in future, that little thought will be at the back of your mind - is he coming back today? And it's all my fault. Where's the emoticon for an evil laugh........
Old 06-10-2003
1K Silver Member
HHHMMMMMMMHHHHAAAAAAAAHHHHHHHHHAAAAAAA!!!!!!!!!!
Old 06-10-2003
Lost Cause
Oh Bill, you're just padding your post count now. I'd have thought you were above that sort of thing. Especially now you know you're being watched..........
Old 06-10-2003
1K Silver Member
130!
It wasn't me, it was, THE GHOST!!!!!!!!
Old 06-14-2003
branded's Avatar
branded branded is offline
Senior Member
branded is on a distinguished road
Re: VF-80 -- a buzzy noise...
I HAVE THE VF08 AND THE SAME THING HAPPENS TO
IT SOMETIMES. I DON'T HAVE A CLUE AS TO WHAT CAUSES
IT BUT IT IS PRETTY ANNOYING. I NOTICED SOMTIMES
THAT THE EXACT SAME THING HAPPENS TO MY PC, EVERY
TIME I MOVE THE MOUSE AROUND IT MAKES THE SAME NOISE
AND IT COMES AND GOES.
  #12
Old 06-14-2003
1K Silver Member
wiring...
I'll bet you have an errant wire causing the issue, or perhaps something like a dimmer switch causing the problem. Other than this, my VF80 has been entirely without buzz.
  #13
Old 06-14-2003
branded's Avatar
Senior Member
Re: wiring...
YA, COULD BE SOMTHING LIKE THAT. IT HASN'T HAPPENED
IN A WHILE SO I DON'T REALLY CONSIDER IT A PROBLEM.
IV'E ACTUALLY RECORDED A TRACK WITH THAT BUZZ
AND I COULDN'T EVEN HERE IT ON PLAYBACK.
  #14
Old 06-14-2003
Lost Cause
"IV'E ACTUALLY RECORDED A TRACK WITH THAT BUZZ
AND I COULDN'T EVEN HERE IT ON PLAYBACK."
Well, that kind of proves it. The same with vampires and mirrors apparently. Have you guys checked your crockery recently?
