Behringer mixer
Anybody have experience with the Behringer mixers? They are pretty cheap and I only need it occasionally.
http://homerecording.com/bbs/showthr...threadid=85695
And there a lot more threads like that. The search option is very useful. |
Re: Behringer mixer
This is a joke right!!?? |
Re: Behringer mixer
Never hear d of a Behringer MX8000.
Maybe you mean the MX9000? 1st off, you cannot compare Behs's MX pre's to Mackies VLZ's as the MX's preamps only have an input sensitivity rating of only -+12dbu while the rated input sensitivity of Mackies VLZ's go as hi as +23dbu's making the MX9000 an unacceptable unit when using hi-sens mics' for drum-micing! I could go on and on but I've wasted wayyyy to much time on Behringer mixers! All I can say is, if you're happy, then I'm happy! |
I'm just curious, but have you ever done an A/B comparison bet the Mackie and the Behringer? The SR Series has a low-cut filter centered @ 75hz; The MX doesn't. The MX's pre/post auxes has a gain of only 15db while the SR's ride at 22db. The MX's XLR input range maxes out at 14dbu's;SR's peak at 28! Let's not EVEN go into eq shelving capabilities (lo&hi) as the SR's surpasses the MX's range in freq'y processing by at least -/+12-14dbs. Power consumption? The MX's uses a ridiculously 400watt power supply supposedly to allow for improved transient responses whereas the SR's uses 5x less power yet provides equal or better than signal translation(& mind you, this is from a Company that supposedly copied Mackies design yet scrimped on perf components!). You state that they both "sound the same"! I can't understand how you arrived at that conclusion when SR provides superior quality in signal translation,freq'y processes and overall operation than the MX. Don't get me wrong, I'm NOT stating the Mackies are the BEST out there, but by FAR, an overall better unit than Beh's MX's! Peace. A Former & NEVER AGAIN Owner of Behringer "SUCK-@SS" Mixers. Q.rM |
Im using a little 8 channel on my karaoke rig that has been perfect ever since Ive had it. But Id buy a soundcraft if I could do it over.
I have an mx9000 & find it a little noisey, a little crosstalk, the eq is just ok, the pots & faders are all quiet but some of the buttons are noisey. This is just a toy for me, if I were serious about studio mixing I definately wouldn't choose this mixer. It's all for fun anyway, isn't it?
The specs I have stated were provided during A/B analysis by well-known engineer,Bill Parks @ prorec. Using an omni mic on a single channel on each board, mic'ing a snare and amp-micing, he was able to determine signal-input sens't'vity ratings of each boards pre's, effective freq'y cut/boost and sweeps and total output performance. Guess what, Mackie rated higher in all aspects more than 2 fold! Both sound alike? Please. Brutha', I mean no disrespect whatso-ever, but run a playback a single track thru each boards outputs and keep eq on both flat. Using the same monitors and amp,listen carefully to the channel's output. You WILL notice some sort of "discoloration" or such emanating from the Behringer due to it's large transformer mixing line noise with signal. The post prior to this one sums it all up in a nutshell! However, like I said prev'ly, if U're happy than I'm happy 4 you! Nuff said! Peace Q.rM |
#12
#13
Whatever!!
Have fun with your "mixer". |
