Old 06-08-2003
werewolf831 werewolf831 is offline
Senior Member
werewolf831 is infamous around these partswerewolf831 is infamous around these partswerewolf831 is infamous around these partswerewolf831 is infamous around these partswerewolf831 is infamous around these parts
simple high pass filter question
My mixing board has a low cut switch (high pass filter) on every channel. I keep this emgaged whenever I record most of my tracks, ok, all of my tracks. Now then, When I monitor what I've recorded and make my stereo mixdown, I still have all of these engaged...should I not? Am I putting my tracks through a low cut twice? BTW I'm using a Mackie 1604 and an adat, mixdown to the PC.
Thanks in advance.
Old 06-09-2003
roman roman is offline
Senior Member
roman is on a distinguished road
I would record blank and use the high pass on mix down. If it needs that!
just listen and decide if there's too much low rumble on the track... it's also just a matter of EQ taste.
- ro -
Old 06-09-2003
Fletcher's Avatar
Fletcher Fletcher is offline
Force of Nature
Fletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond repute
Anytime you add a filter you're adding a "phase shift" to the signal. The cumulative effects of this 'phase shift' may lead to a "smaller" sounding overall event.
FWIW, I'm from the "when in doubt, leave it out" school of engineering... especially when things like Mackie desks are involved.
Best of luck.
Fletcher
Mercenary Audio
mwagener wrote on Sat, 11 September 2004 14:33
We are selling emotions, there are no emotions in a grid
Old 06-09-2003
moley moley is offline
Senior Member
moley has a reputation beyond reputemoley has a reputation beyond reputemoley has a reputation beyond reputemoley has a reputation beyond reputemoley has a reputation beyond reputemoley has a reputation beyond reputemoley has a reputation beyond reputemoley has a reputation beyond reputemoley has a reputation beyond reputemoley has a reputation beyond reputemoley has a reputation beyond repute
Like Fletcher said, filtering causes phase shifts (EQ in general does, but filters in particular) - so perhaps you shouldn't do it needlessly.
If you have the facility, look at the waveform of a square wave, before and after you've applied a high pass filter (make sure the cutoff frequency is well below the frequency of the square wave).
Even though the filter is well below any frequency present in the square wave, what you'll see afterwards don't look much like a square wave
Granted, you're unlikely to hear the difference with just a squarewave...
The Cuervo Gold
The fine Colombian
Make tonight a wonderful thing...
Old 06-09-2003
Senior Member
Thanks for the replies.
I'm not too familiar with phase shift. Can this make things seem slightly off key? Also, how do you make a square wave form?
Thanks,
werewolf
Old 06-10-2003
Senior Member
It's a change in the phase relationship between the different frequencies that compose a signal.
If you imagine that every sound can be made up from sine waves at particular frequencies and relative volumes - then what filtering does is to shift those sine waves "sideways" by some amount, so the phase relationship between the constituent sine waves (frequencies) is different. This happens with filtering, even with the frequencies that aren't directly affected by the filter. If you're filtering out all frequencies below 20hz, that still causes phase shifts with the rest of the frequency spectrum.
Unless, you have the facility to do linear phase filtering.
With a tone generator. I presume from that question that you don't have the facility to, or if you do you've never found it
Here's what it looks like (second one down):
The Cuervo Gold
The fine Colombian
