Old 06-07-2003
ScienceOne ScienceOne is offline
Dedicated Member
ScienceOne has a reputation beyond reputeScienceOne has a reputation beyond reputeScienceOne has a reputation beyond reputeScienceOne has a reputation beyond reputeScienceOne has a reputation beyond reputeScienceOne has a reputation beyond reputeScienceOne has a reputation beyond reputeScienceOne has a reputation beyond reputeScienceOne has a reputation beyond reputeScienceOne has a reputation beyond reputeScienceOne has a reputation beyond repute
Sample Rates From Satan!!! 88.2??
On cubase sx, when recording 8 tracks of drums from my delta 1010, it sounds great in both 44.1 and 88.2. However, in 88.2 the syncronization between the visual of the files and the actual audio is off. The audio will end long before the visual is over. Its almost like the visual is still set for 44.1!!!!!!! The playback is fine though!
I change the settings on the 1010 when i go from one sampling rate to another, but do i need to do the same in cubase? cause i havent. Recording could work but editing would be pure hell. Someone help.
Old 06-07-2003
bleyrad's Avatar
bleyrad bleyrad is offline
Force of Nature
bleyrad will become famous soon enough
yes, you need to set it in cubase.
the delta's samplerate setting is irrelevant - it automatically will switch back to whatever cubase is putting out.
Old 06-07-2003
Dedicated Member
how do i set it!? i went to the project menu and it wouldnt let me select a sample rate, it jsut wouldnt let me.
