Old 06-06-2003
guitar roy guitar roy is offline
Newbie
guitar roy is on a distinguished road
Quieting Down Loud Drums
We have a practice/recording situation where the drums sound good on the recording but are acoustically very loud in the room.
Any ideas how to quiet down the drums without materially altering the quality of the sound that gets recorded, and without telling the drummer to "play quiet"?
Thanks.
Roy
Old 06-06-2003
4-Man Takedown 4-Man Takedown is offline
Senior Member
4-Man Takedown has a little shameless behaviour in the past
You probably need to give some more info, like mics and placement and stuff. All I could recomend is to move the guitars closer to the mics, or turn em up.
Old 06-06-2003
Newbie
We are triangular micing with two MXL63's overhead and a PG52 in the kick. I don't think that Mic placement is the issue because the recorded sound is fine and everything else (bass, guitars) goes direct into the recorder (D1600).
The question is how to reduce the acoustic volume of the drums in the room without it sounding dead. Basically our ears are hurting!
Thanks.
Old 06-06-2003
Prizmaxic Prizmaxic is offline
The Shizz
Prizmaxic is on a distinguished road
If you like the sound on the recording, why not just wear isolation headphones, or earplugs?
Old 06-07-2003
Newbie
Prizmaxic,
Good point. This is just practice and the recording is more for working on our material rather than any finished stuff. The guys in the band aren't crazy about wearing earplugs because they can't hear very well, and its only the drums that we're having trouble "turning down".
Having said that maybe we're using the wrong kind of earplugs. Any suggestions on good ones that reduce the sound pressure without materially affecting the quality of the sound?
Thanks.
Roy
Old 06-07-2003
Senior Member
Go to Tower Records or Guitar Center. Either grab the clear ones from tower or the orange ones from guitar center. Both are hearos I believe, and are high fidelity. Basically the volume will go down and it will still sound good. Actually I think it practicing sounds way better with them on.
Old 06-08-2003
outlawtorn86's Avatar
outlawtorn86 outlawtorn86 is offline
Senior Member
outlawtorn86 is on a distinguished road
they make plexiglass walls that go in front of the set. just make sure when ur recording the mics are on the same side as the drums, and ur standing on the other side. the thing isnt that expensive
Old 06-09-2003
Chibi Nappa Chibi Nappa is offline
Force of Nature
Chibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond repute
I always wear earplugs in the practice room. If you get the right ones, you can even hear your part better, especially if you are a singer. I used the Hearos for a very long time, and found them to be quite good. The only problem was that they were a pain in the ass to constantly remove/insert once the song ended, so I went and got some of those big ass ear mufflers like you see guys wearing at the shooting range.
However, if you really want to turn the drum volume down, companies do make thick rubber pads to rest on top of the drum skins and cymbals. It doesn't change the playing feel too much, and it doesn't change the drum tone too much, but it kills the cymbal sound. We have them. Great for practice, bad for recording.
Old 06-09-2003
Fletcher's Avatar
Fletcher Fletcher is offline
Force of Nature
Fletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond repute
We have these little "skwishy" orange foam plugs that we give away with every order... they're pretty similar to the E*A*R plugs you can get at pretty much any drug store in Amerikkka...
I don't know what you're looking for in an ear plug... but these things have served me very well over the years.
Fletcher
Mercenary Audio
mwagener wrote on Sat, 11 September 2004 14:33
We are selling emotions, there are no emotions in a grid
Old 06-09-2003
Newbie
Thanks for your replies. Sounds like the Hearos Hi-Fi is the way to go.
Chibi Nappa, were you using the "Hi-Fi" version of the Hearos? They look easy to remove with the stem. The more conventional "wad" Hearos look like they would be difficult to remove. Also, why remove in between songs, why not just leave it in for the entire session (not comfortable or trouble hearing?)?
Thanks. Roy
Old 06-09-2003
Force of Nature
I just used the standard Hearos. And I remove them for several reasons. For instance, we all use new patches and such when writing a new song. It helps to hear that clearly. And sometimes you just want to hear what the heck the drummer is saying between songs.
  #12
Old 06-09-2003
Newbie
Chibi Nappa, can you recommend any drum pads in particular?
Thanks. Roy
  #13
Old 06-10-2003
cstockdale's Avatar
cstockdale cstockdale is offline
supafly killa homey
cstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud of
why would you want to hear what your drummer has to say?
  #14
Old 06-10-2003
Force of Nature
Thanks. Roy
I'll ask the drummer what he bought. I don't know what they are off the top of my head, but I really like them. I'll get back to you...
  #15
Old 06-10-2003
Force of Nature
Har har. Actually the guy is quite tallented at song arrangement.
