Hi,
You might remember me from a bit ago, I've got a new song for you! Better recorded I think, but you can decide for yourself of course! http://www.nowhereradio.com/tomewer/singles It's "Something New". Tell me what you think! Thanks. - Tom |
bump...
you have to give it some time bro.. It usually takes more than an hour or so.. Maybe instead of bumping your own thread, check out someone elses? Just a suggestion.. It may or may not work..
nice song.. there are some bad plosives.. Like maybe you need to retrack the vocals with a pop screen.. the drums come in way too loud imop.. the snare drum engulfs everything.. at the very least bring down that snare if possible.. |
There are some pitch & timing issues on the vocals when the backups come in.
The strummin' guitar thing really can't carry the tune all the way past the 3min mark. You need to have the rest of the instruments come in sooner, and stay longer. When the drums & electrics kick in there are some more timing & intonation issues. That lead guitar tone is way too buzzy sounding for something like this. I liked the bass line. ![]() |
I made up the backing vocals just as an idea while I was listening through the song, I will work on them. What do you mean by buzzy sounding? I'm not sure what kind of tone to use for this, do you mean less distorted? I'm going for an emotional sounding kinda solo, I'm sure you can see that. Also, my guitar's giving me a huge headache, I spent a long time trying to fix the intonation but it is still off!! I would take it to a tech and get it properly done, but unfortunately I don't have that kind of money. ![]() Thanks very much for the advice! P.S. what do you think of the birds at the start? I had the window open when recording and noticed their chirping after I'd recorded the acoustic guitar, thought it sounded kinda cool. Keep or chuck out? |
Buzzy would likely be a combination of too much gain, and too much presence. I very rarely run the gain on any of my amps above 7, and most of the time it's around 5. I can crank 'em up real loud here in the daytime though to get the power tubes distorting. Quote:
It could be that your nut is too high. Does it go sharp when you tune the open strings then play down near the nut? That's real common on cheap guitars. Cutting the slots deeper is not a big job, but it's real easy to screw it up too. A quick Google search on the subject should give you some good info on guitar setup techniques. Quote:
I say leave 'em. I dig stuff like that. Makes the recording sound "honest". ![]() Last edited by M.Brane; 06-06-2003 at 17:23.. |
Yeah that guitar is too rough, or overdriven. what kind of drum sounds are you using?
Well, I'm not sure how to put this. I think the song itself is pretty good, writing-wise. I think the performance is pretty shakey all around. I think I'd have left those BG vox out. Needs some work, but I think with the right sounds this would be a pretty good tune.
#12
#13
Yeah, Some background vox would be cool, but I think as is they kind of step on each other, you know? Maybe you could drop the BG's back a little, or add some long reverb. Just an idea though. I did like the bass line pretty well. The drums just kinda jump out at you, though, and most of this tune call for a more laid back sound. Just my opinion though.
#14
#15
I've never used Ntrack, but surely it supports plugins? There are plenty of free effects plugins to get started with. try Directxfiles.com . Once you play around with some compression and reverb, You'll discover what you've been missing.
#16
#17
Listening now in lo-fi, so can't give you much sonic advice.
Arrangement wise, this kind of needs to go somewhere. I think the writing is fine, but there is really nothing to fill out the arrangement for a good two minutes until the bg vocals come in and then the drums and electric at the 3 minute mark. I'm not sure what it needs, but it needs something because the verses get a little bit old by the time anything begins to happen. This kind of sounds like a guitar demo which is fine if that is all you are going for, but, to keep the audience interested, I think this needs to have some kind of arrangement filled in -- maybe some percussion -- I don't know, just something -- imho -- ![]() I think the background vocals are a good idea, but they were a little bit off pitch wise (and I have tons of pitch issues, so I guess it is okay for me to say this -- I know I need a lot of work in this department as well) The drumming on my end seemed a bit out of place...not sure if it is the sound or just the levels, and the electric was a nice touch, but again, when the arrangment is not building towards it, it kind of seems a little bit anti-climatic. Sorry if it sounds like I'm being harsh. I just really think this song deserves a second chance...build an arrangement and see where it goes. Experiment, add some strings, add some percussion, see if it makes a difference? Maybe it will, and maybe it won't, who knows, all you can do is try. Check around for different sounds and just go for it. This is just my $.02 and since I don't know much, take it for what it is worth. Thanks for giving us a listen! ![]() |
#18
I'd love to have strings, I've always thought how great it would to have some in some of my songs, but I haven't got a violinist/orchestra handy! Any advice on computer generated strings, or whatever they're called? Thanks for the advice! |
#19
#20
![]() I'm sure there must be something free to get started on? I hope, because I am beyond broke at the moment! |
