Old 06-06-2003
Pier Calacino Pier Calacino is offline
Dedicated Member
Pier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond reputePier Calacino has a reputation beyond repute
Question Signal Chain Question ?
Hello All,
Does it defeat the purpose of a good stand-alone mic pre to patch it through a board and then to the recording device ?
Shouldn't you go directly to the recording device rather than through a mixer board?
Unless thats the color/sound you want?
Pier
Old 06-06-2003
The Green Hornet The Green Hornet is offline
Been Here, Posted That
The Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond repute
Talking
OLA Pier:
I guess most folks would say the more patches you patch in, the more it may or may not affect the signal.
I run my mic into the Grace 101 then out of the Grace into the Yamaha 2816. It works fine.
You can try running your mic signal both ways and see what gives you the best result. But, I'd guess there won't be any extreme difference.
Happy Summer
Green Hornet
Old 06-07-2003
FZfile's Avatar
FZfile FZfile is offline
Dedicated Member
FZfile is on a distinguished road
Unless you want to monitor just the pre...
Sometimes you may want to monitor the sound going INTO the recorder before it goes through any of the recorders circutry.
They say the shortest path possible is always the cleanest but if you have a decent mixer you may only be adding a negligable amount of signal change.
I have every thing plug into my patchbay first because I can then split the output and route to multiple destinations.
Like I may plug my mic pre into the Track1 input of my bay (which is essentially direct) but then split it to also go into my compressor and then maybe EQ (maybe not) and then to Track2 so I can then mix a compressed and uncompressed track to taste .......or even just to a/b the tracks.
A mixer will allow you options that may outweigh any amount of added noise or whatnot, but it depend if you need or want those options during tracking.
But anytime you add circutry tothe signal path you are going to change the sound....however slight.
-mike
Old 06-07-2003
mixsit mixsit is offline
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Don't know if others do this, but with mackie, line-in is through a pad, tossing some gain, then back up into it's mic pre.
I like to have a pre with one direct line to the converter, and a second or split going to the mixer for no-latency monitoring.
Guess it depends a lot on how you like to work it.
Wayne
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Old 06-08-2003
Dedicated Member
Hi guys,
Thanks for the replies.
I just thought if your were after a particular sound with a pre, and you put it through another pre that you didn't like, that would defeat the purpose?
Pier
Old 06-10-2003
sweetnubs's Avatar
sweetnubs sweetnubs is offline
Force of Nature
sweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond repute
holy flying pigs it's the day hell froze over. why on god's green earth would you buy an outboard preamp, run it through your mixer, then to tape? it defeats the purpose of buying an outboard preamp. monitor your "tape" returns through your mixer. A good solution is to buy some decent outboard preamps and by bypassing the mixer and using it for monitoring only, you get better quality tracks which then you can take to a real studio and mix down.
Old 06-11-2003
christiaan's Avatar
christiaan christiaan is offline
1K Silver Member
christiaan has a spectacular aura aboutchristiaan has a spectacular aura about
Joemeek preamps (maybe others too) have a cool feature.
Two identical outputs
One goes to the recording device, the other one is for monitoring.
Old 06-11-2003
gordone's Avatar
gordone gordone is offline
1K Silver Member
gordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond repute
My soundcard (Delta 44) is capable of routing an input directly to an output, so I have my outboard pre go into an input for tracking, but I then route that input to an output, which goes to my mixer for monitoring, so I have a whole channel strip for the monitor signal (along with its aux send, panning,, and fader), but the recorded signal stays unadulterated by the mixer.
