MR8 to CD Recorder
Hi, I have two questions on recording from the Fostex MR8 to a CD Recorder. 1.) Do I have to convert tracks 1>6 to 7/8 to make it into a stereo WAV file or can I just play tracks 1>6, mix them and record them to a cd recorder as it plays? 2.) What CD recorder do you folks suggest for recording from the MR8. I know it has to have the digital input. Also do you need DA cd's or will any recordable cd work? Thanks a ton!!
Welcome Big John. You do not have to mixdown to 7/8 before transferring to a CD recorder. You can either go with an analog mixdown using the stereo out jacks on the MR-8 or you can go digital with the digital out jack. Either way you mixdown to CDR. In other words you need to rehearse the mixdown so you will have everything at the proper levels when it gets to CD.
Thanks for the reply Gospel. Do most of the cd recorders have the same digital input as the digital output on the MR8. I haven't seen many cd recorders with the same kind of digital input? Thanks again.
When I purchased my standalone cd-recorder almost three years ago, I understood that s/pdif optical i/o jacks were standard. I would be very surprised if that has changed. If not, and the only digital i/o jacks are coax, Fostex does make a converter.
"Tolerance is a virtue only to those who will believe anything." G.K. Chesterton |
