SP-B1 Different color dots...
I ordered a pair of B1's from 8th Street Music and they said they'd be sending B1's with the same color dots on the box, but instead they sent a red and a black... From talking to Brent at SP it seems the difference would be about a decibel in sensitivity between the two mikes, but not in sound. Question, does anyone think I will actually hear a difference if I use these in stereo array to record a choir? Should I send one back to match the dots?
Even though the difference between these mikes may be very small I would, if I were you, get in touch with 8th Street and make them correct their mistake.
If you want a matched pair of Studio Projects mic's... you need to get two mic's with the same color dots.
-33~-34dB +/-.5dB, is marked by a red dot on the packaging -35~-36dB +/-.5dB, is marked by a green dot on the packaging -36~-37dB +/-.5dB, is marked by a black dot on the packaging |
Thanks all!
Even now, as we speak, I am moving to "connect the dots" and 8th street will be sending out another microphone. Let's see, I have a red and a black... What are the chances they'll send a green?!
If you want green dots, ask 8th street if they have two with green dots (if they do) ask them to send those to you.
I'm sorry, I thought you were serious... oh well, never mind.
Wow this is like Instant Messenger!
OK, this is weird. I just got a pair of B1's from Sweetwater.com ($79.99 each). They don't have a dot on the box (!). However, they have sequential serial numbers and the sticker on the side says:
B1Mic StPr Cardiod Condensor Mic 208948E3 Both mics have an identical sticker, including the number on the end. Is this sticker just Sweetwater's labeling....or does StPr refer to Stereo Pair? -lee- |
check on the manual, registration card....mine came with the stickers in the box and inside the manual
Thanks for the suggestion! I didn't see anything on the inside of the box - but both mikes had a black dot on the registration card.
-lee- |
#12
Alan Hyatt PMI Audio Group Studio Projects Joemeek Toft Audio www.pmiaudio.com |
#13
The dots...
