Old 06-03-2003
Orpheus Orpheus is offline
Senior Member
Orpheus is on a distinguished road
Mic preamps on Mackie 32x8 vs. Standalones?
hi.
personally, i wished the mic preamps on my Mackie 32x8 had more gain. much more. .... but besides that, how do you think they stack up against the standalone preamps? at what price range of preamps would the Mackie preamps be equivalent to?
also, i heard that the VLZ mackie preamps aren't bad. are my mackie preamps the same or better?--i would think so, considering the 32x8 costs like 3-5 times more.... but i never see Mackie advertise such techology on the 32x8.
the reason i'm asking is that i'm contemplating getting a real mic preamp.................. so, if i spend less than $500 on the mic preamp, would i really be that much better than what i already have?
thanks.
www.fallingtodreams.com
Old 06-03-2003
Dot Dot is offline
1K Silver Member
Dot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond repute
Orpheus, VLZ pres are certainly usable - but when you use more than a few at a time it starts draining on the power supply. So, one channel of VLZ is going to sound much better than 24+ channels.
In comparison to other external pres, I'd say the VLZ is better than the very cheapest - but even when you get into pres like the DMP-3 and the VTB-1, you've already surpassed the quality offered by the VLZ. Pres in the $500 - $1000 range - such as the RNP, Grace 101, A Designs MP-1, John Hardy M-1... you get into a completely different scale of sonic quality.
Yep. In the $500 and under range - look into the Grace 101 for a clean single channel or the RNP for a dual channel that has a bit of color. For $200 and under, the DMP3 offers two clean channels and the VTB-1 single channel offers versatility.
Dan Richards
Digital Pro Sound
The Listening Sessions
Dan Richards
Yackin' about gear and recording techniques at Studio Forums.
Old 06-03-2003
Fletcher's Avatar
Fletcher Fletcher is offline
Force of Nature
Fletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond repute
Uhhh... what Dan said, to a point.
Things like the VTB-1 are pretty much a similar design as the Mackie with the capability of adding some quasi-ugly [not that that's a bad thing... it just ain't a pretty thing] distortion to the signal.
The design on the Mackie pre's is an IC op-amp based design which in this particular situation lacks headroom, depth, and real definition to the tone... as you get into pre's that are designed to a higher standard, you get a 'higher standard of audio' as a net result.
Fletcher
Mercenary Audio
mwagener wrote on Sat, 11 September 2004 14:33
We are selling emotions, there are no emotions in a grid
Old 06-03-2003
Senior Member
thanks guys.
.....i keep hearing about this RNP. who makes it?
also, are the pres on my 32x8 the same as those on the cheaper mackie boards?
Old 06-03-2003
jake-owa's Avatar
jake-owa jake-owa is offline
Banned
jake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud of
Yes the pres in all VLZ boards would be the same ones.
Here's the RNP and RNC maker, FMR audio.
www.fmraudio.com/
Old 06-03-2003
Senior Member
my god that thing is ugly! man, i sure hope the music it makes sounds better than it looks!
Old 06-03-2003
jslator jslator is offline
Dedicated Member
jslator has a reputation beyond reputejslator has a reputation beyond reputejslator has a reputation beyond reputejslator has a reputation beyond reputejslator has a reputation beyond reputejslator has a reputation beyond reputejslator has a reputation beyond reputejslator has a reputation beyond reputejslator has a reputation beyond reputejslator has a reputation beyond reputejslator has a reputation beyond repute
I don't think that's quite right. I don't think the Mackie 8-busses ever incorporated the newer XDR pre's, or if they did, I think it was quite some time after the mini-mixers started using them. Is your 8-bus a "non-VLZ" a "VLZ" or a "VLZ-Pro"?
Old 06-03-2003
jake-owa's Avatar
Banned
I was just trying to say that the "VLZ" pres would be the same no matter which board they are in. "VLZ" pro (XDR?) would be a different thing as would non "VLZ" obviously.
Old 06-03-2003
Senior Member
how would i find out? it's not like it says on anywhere on the board or power supply. it says "32x8x2 8-Bus Mixing Console." i don't have the original manual.
Old 06-03-2003
Dedicated Member
In that case, it's the non-VLZ. Those are the first generation preamps.
Old 06-03-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Mackie 8-buss mixers don't have either the XDR nor the VLZ pres... as JS said, they contain the original Mackie pres.
That being said, I have no trouble making mine work for me - I use the 24*8!
  #12
Old 06-03-2003
Senior Member
but do you mean to imply newer 8-bus's have these XDR or VLZ preamps?--or no 8-bus ever had these preamps?
  #13
Old 06-03-2003
According to Mackie, none of the 8-buss mixers ever had them, nor will...
  #14
Old 06-03-2003
Senior Member
thanks.
if that is so..... then perhaps the 8-bus mixers have better preamps than the other mackie mixers? or worse?
  #15
Old 06-03-2003
jake-owa's Avatar
Banned
I didn't know that.
I've heard many people who like the original Mackie pres the best. It's debatable.
I find them very usable for rock music.
  #16
Old 06-03-2003
Dedicated Member
I think the general consensus is that they're worse, though I've heard of a few people that like them better. Either way, they'll be workable but far from spectacular.
  #17
Old 06-04-2003
chessparov chessparov is offline
Three Thousand and Counting
chessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond repute
Wink
Fletcher, with all due respect, must disagree on the "VTB-1 pretty much a similar design..." comment. Both the VTB-1 and DMP3 are appreciably quieter when run at full gain compared to the Mackie's "hiss".
(the edge on "quiet" goes to the VTB-1)
The DMP3, as pointed out by Chessrock previously, is Burr-Brown based. The VTB-1 is discrete A/B.
Not that that means anything necessarily by itself, however, I suspect some of the "superior" sound of each relative to a Mackie's cheap op-amp is due partly to these design differences.
There are certain microphones BTW, that match up to the VTB-1
just fine, like the (200 Ohm) Beyer M88's, or Sennheiser 421's. Quite a respectable sound, even for a pro level studio IMHO. Running a SM57, when it's set on 50 Ohms, fattens up the sound to create interesting results too.
Chris
P.S. Fletcher, I hope all this talk of "cheap" pre's doesn't seem
like discussing whether Ripple, Boone's Farm, or Stawberry
Hill is "best"!
