Old 06-03-2003
KevinTran's Avatar
KevinTran KevinTran is offline
Senior Member
KevinTran is on a distinguished road
Use of external EQ and Effects processor
Hey guys,
I wasn't planning on using a Peavy EQ and a Digitech Effects Processor that I have for recording since most tracks can be manipulated via software.
But it sucks to have things just sitting around. Are there benefits to controlling the feed going in to the soundcard versus doing all effects and eq'ing on the computer?
kt
Old 06-03-2003
jake-owa's Avatar
jake-owa jake-owa is offline
Banned
jake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud of
Kevin, the main advantage to hardware processing is it usually sounds way better.
Try recording a dry track and a completely wet track effected by your outboard processor. You can choose to mute the wet track until mixing and use as much level from that as you want to add reverb or delay ect.
Old 06-04-2003
KevinTran's Avatar
Senior Member
thanks jake
Old 06-11-2003
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
But for it to sound way better you have to be using way better outboard gear. I think there are plugin eq and processors that will sound better than the Peavey and Digitech mentioned here.
The main reason to use this specific hardware would be for any particular color or sound that may be unique to it. As far as quality alone, I think a good plugin can beat both.
However, I do agree that plugins can't yet match really fine analog gear or high end outboard processors.
Old 06-11-2003
jake-owa's Avatar
Banned
I disagree, I have a plugin for the 480L that I would never use before my digitech outboard. I find plugins make a mix sound two dimensional and scimpy, they really are no substitute in my opinion.
