Old 06-01-2003
moose54 moose54 is offline
Newbie
moose54 is on a distinguished road
Soundcards
Okay please I’d love some help here. I'm just starting in the world of recording. I have made recordings back at skool and the likes but I want to start getting into it at home.
I want to be able to record rock bands so that means drum kits. So preferably I’d like a sound card that I can feed 6 (minimum) audio inputs to and record them as individual tracks simultaneously.
I've had a look around and seen things such as the AudioTrak INCA88 which has 8 inputs, however its not very clear. Would I require a mixer/preamp for the mics or could I use 8 mics direct to the 8 inputs??? Is it worth using a mixer anyhow as I would have much more control over the sound.
But I guess the biggest question is... Is there a better solution to my problem??
also any basic standard mics I can use for "all round" type work would be great..
thanks for any help you can give.
cheers
Old 06-01-2003
Gidge's Avatar
Gidge Gidge is offline
Lapdance Test Dummy
Gidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond reputeGidge has a reputation beyond repute
Cool
the INCA has 2 mic preamps, so more mics would mean more preamps needed.....no you cannot run a mic straight into the inputs of the INCA (besides the 2 that are preamped......
good starter mics:
pair of Marshall MXL990's : good for drum overheads and acoustic instruments such as acoustic guitar,horns,etc
Shure sm57 : snare drum,guitar amps,background vocals
AT ATM PRO25 : kick drum, bass amp
Marshall MXLv67G : vocals, drum room mic
Old 06-01-2003
Gidge's Avatar
Lapdance Test Dummy
Cool
A great card similar to the INCA in features is the Delta 1010lt ($249).....
the INCA appears to be discontinued so driver support may be a problem and it just doesnt seem to come close to the 1010lt in quality......
Old 06-02-2003
Bass Master "K"'s Avatar
Bass Master "K" Bass Master "K" is offline
Force of Nature
Bass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud of
It's a step up in money, but the Aardvark Q-10 is an all in one package that would do everything you need and you wouldn't need the pre-amps or the mixing board. 8 inputs (10 if you count the two digital, but I don't), class A pre-amps, takes both XLR and 1/4', 4 inputs with phantom power for those condenser mics, hi-z on 2 inputs...
It's been great for me. Runs around $800
