Old 06-01-2003
arcaxis's Avatar
arcaxis arcaxis is offline
Force of Nature
arcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond repute
XLR or Balanced 1/4" for Outboard Gear??
A few of the audio processors I have are fitted with XLR and 1/4" balanced outs. When interconnecting this gear, for instance a mic pre into a DAW that has XLR and balanced ins, is there a prefered way? It just seems that XLR ins on a DAW are for mics rather than outboard gear and maybe the 1/4" is more appropriate.
Old 06-02-2003
Jeyan's Avatar
Jeyan Jeyan is offline
Force of Nature
Jeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond repute
If you have a inbuilt pre amp connected to your XLR inputs then they are meant for microphones, but the XLRs in the signal processors are just the same as balanced stereo 1/4". Makes no difference expect that the terminals are a little farther than 1/4".
JJeyan
Old 06-02-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
It all depends on the gear...
On some gear, when they have both XLR and 1/4" they will run +4dBu thru the XLRs and unbalanced -10dBV via the 1/4"....
Or other times, both will be balanced +4dBu.... in which case it doesn't matter which you use.
You'd have to read the I/O spec in the manual to know for sure...
