Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 06-01-2003
tubedude's Avatar
tubedude tubedude is offline
His Majesty
tubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond reputetubedude has a reputation beyond repute
Where can I find a cheap functional ORTF bar?
Anyone?
Peace!
Paul
Old 06-01-2003
Mark7's Avatar
Mark7 Mark7 is offline
Human 2.0
Mark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond repute
Hey Tubey!
Define cheap. Studio Spares sell a K&M Stereo Bar that costs around £10. Is that cheap enough?
Orbiting this at a distance of roughly ninety-two million miles is an utterly insignificant little blue green planet whose ape-descended life forms are so amazingly primitive that they still think digital recording is a pretty neat idea.
Old 06-01-2003
Jeeper Jeeper is offline
Junior Member
Location: Louisiana In same town as Jim Croce's last gig
Jeeper has a reputation beyond reputeJeeper has a reputation beyond reputeJeeper has a reputation beyond reputeJeeper has a reputation beyond reputeJeeper has a reputation beyond reputeJeeper has a reputation beyond reputeJeeper has a reputation beyond reputeJeeper has a reputation beyond reputeJeeper has a reputation beyond reputeJeeper has a reputation beyond reputeJeeper has a reputation beyond repute
I've bought a couple of multi mic bars here but each time had problems getting my mics into ortf using them. What I ended up doing was using one of the short multi bars I bought with it on the stand mounted using one of the end mic holes. Then I used the clamp on bar only that came with one of my pop filters clamped to the mic stand just under the end. All worked out fine from there. This gave me lots of control of elevations by sliding the clamp on up and down. The mic spread was controled by the angle of the two bars with respect to each other.
Worked here but YMMV.
Good luck.
Old 06-02-2003
sloop's Avatar
sloop sloop is offline
Dedicated Member
sloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond repute
Build one
I built one using good wood stock, standard flange bases for mic mounts. I rigged to either mount on a microphone stand or hang from cables. Just measure carefully. I pre-marked the base on mine to obtain the proper angle for the mics.
Old 06-02-2003
kid klash's Avatar
kid klash kid klash is offline
The original Mr. Nice Guy
kid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond repute
Full Compass sells a metal one for around $35.
Old 06-02-2003
Innovations's Avatar
Innovations Innovations is offline
1K Silver Member
Innovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond repute
Atlas TM1 looks good. Musicians Friend sells them for $15
http://www.atlas-soundolier.com/tech.../SL11.1398.PDF
Also this axman unit
http://www.musiciansfriend.com/srs7/.../base_id/40685
My understanding is that an ORTF pair is just two cardoid microphones 17 cm apart with an angle of 110 degrees between them, correct?
Old 06-02-2003
DigitMus's Avatar
DigitMus DigitMus is offline
Dedicated Member
DigitMus has a reputation beyond reputeDigitMus has a reputation beyond reputeDigitMus has a reputation beyond reputeDigitMus has a reputation beyond reputeDigitMus has a reputation beyond reputeDigitMus has a reputation beyond reputeDigitMus has a reputation beyond reputeDigitMus has a reputation beyond reputeDigitMus has a reputation beyond reputeDigitMus has a reputation beyond reputeDigitMus has a reputation beyond repute
I've got 2 of the Atlas, they work fine for me (using KM184s, Earthworks QTC1s & SR77s, AT 4050s etc.).
SG
Scott
I resolve to quit procrastinating...tomorrow.
