Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 05-30-2003
Raydio's Avatar
Raydio Raydio is offline
Dedicated Member
Raydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond reputeRaydio has a reputation beyond repute
Sync Triton With Sequencer???
I have a Triton and Im trying to sync it up with Cubase SX, my cables are correct; my settings are just wrong. What Im trying to do is simple....
1) Import a drum loop into Cubase SX
2) Start my sequencer on my Triton
3)When the Triton sequencer starts recording, I want Cubase to play the drum loop I imported at the same time.
Its pretty simple but I know my settings are all wrong in the Sync setup, I really do need help with this one guys. Thanks!
Old 05-30-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
They should both be setup for Midi Sync or MTC and one needs to be designated as the Master.
What are you doing is a little screwy and not that common. Why don't you just use Cubase and record the new sequences to that instead of trying to sync up two different sequencers?
Old 05-30-2003
Raydio's Avatar
Dedicated Member
Well, I would use Cubase as my sequencer if I had more knowledge of its quantizing capabilities and so forth. Im very familiar with the Triton's sequencer.
BUT!!! If I find out the exact way to link up my Triton to Cubase and use Fruity VST's sounds; without my keyboard playing its instruments... I would be satisfied. Thanks for the post.
