Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 05-29-2003
Jack Real Jack Real is offline
Dedicated Member
Jack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond repute
Chorus effect to a mix
Hi
I want to apply a chorus/delay effect on my mix. For the delay, I know it should be set according to the tempo of the song but for the chorus, do we have guidelines? The effect will be applied to the lead vocal, the 2 chorus vocals and the accoustic guitar. On the keyboards, I will route the piano, the flute and the wave lead to a separate effect patch on the keyboard. Should that patch on the keyboard matches the one I will apply to the vocals and guitar ? Should I adjust the chorus according to the main instrument of the song (the guitar) or to the lead vocal ? Are the chorus parameters related somehow to the tempo of the song or do we adjust those parameters by ear only ?
The chorus/effect will be applied together because the other effect channel is used for the reverb so what I'm looking for is advices to adjust the effect patch that goes to the whole mix.
Thanks,
Jack Real.
Old 05-29-2003
BrettB's Avatar
BrettB BrettB is offline
1K Silver Member
BrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond repute
well, use your ears in the first place... I don't think there are any standard settings. I'm not sure what your plan is, your post is kinda confusing, but I guess you want to apply chorus on your vocals and acoustic guitar.
I know this is a taste thing, but be carefull with chorus on guitars. If you really want to use them, do it subtile. If you want more space in the guitars, try doubling them or adding small parts. I can't help it, but especially chorus on clean guitars sound very amateuristic to me. Don't forget chorus is a detuning effect...
www.protoolsforum.com
The board for all Pro Tools (LE) users!! Finally back online.
Old 05-29-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Why would you want to chorus a whole mix??????
Old 05-29-2003
scottboyher's Avatar
scottboyher scottboyher is offline
The King Of Nothing
scottboyher will become famous soon enoughscottboyher will become famous soon enough
Don't apply the chorus and delay to the whole mix.
_______________________________
www.scottboyher.com
info@scottboyher.com
Old 05-29-2003
Dedicated Member
scottboyher wrote : Don't apply the chorus and delay to the whole mix.
Blue Bear Sound wrote : Why would you want to chorus a whole mix??????
Hi
Can you tell me why ? I have 2 channel effect on my mixer and 1 is used for the reverb so what is the purpose of the second one ? Is there an effect that you can apply to the whole mix of should I just apply the chorus/delay to some instruments and vocals ? I chosed to record the voice totally dry so now, after a first pass of compression and little reverb, I want to apply a chorus/delay effect to the voices at the mix. I thought it would give more unity to the mix if I applied the same chorus/delay effect to the guitar and keyboards instruments. For example, the sound of the piano, flute and wave lead on the keyboard all have personalized chorus set-up when selected individually (factory setting). Would it be a good practice if all the instruments and the voices had the same chorus setting ?
Note: Even if the same effect is applied to all the instruments, I can select the amount of effect that is applied to each instrument.
Thanks,
Jack Real.
Old 05-29-2003
The King Of Nothing
I am not trying to be a prick but why do you want to add chorus to everything? Are you adding it just because you can?
www.scottboyher.com
Old 05-29-2003
You can certainly experiment -- but generally, effects on an entire mix are not, er... effective!
Typically you would apply the effects you want on one or more individual tracks.
And of course, you only use effects as needed for, er... effect! You don't use them just because you have them!!
Old 05-29-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Good advice from Bear. Chorus is a pretty limited effect and I rarely use it on anything. Stick with reverb and delays unless you are going for a very artificial sound. Sometimes a slight touch of chorus or flanger can help add a little edge, sparkle or stereo feel to a sound but use it very sparingly. Most importantly if you don't need it don't use it.
Old 05-29-2003
Freeform Freeform is offline
Senior Member
Freeform is on a distinguished road
I would certainly reccomend that you not throw chorus or delay on entire mix. Both chorus and delay are used to make something sound thicker and standout. Doing this to an entire mix defeats this purpose.
An effect commonly used on entire mixes is reverb. We often throw it down as a stereo aux on instruments, but often times people mastering albums add just a touch of verb to entire mix. It just makes things sound more complete sometimes.
/Hope I'm not being to obvious here
Old 05-30-2003
Dedicated Member
Hi
Thanks for the advices. Yesterday, I was working on the keyboard tracks and it's true that applying chorus/delay to all the instruments is not good. I use the first effect patch of the keyboard for the drum so I have plate reverb on that one. When I play the drum with all the other instruments dry (piano, flute, bass and wave lead), it sounds pretty good. Then, I tried to apply chorus/delay from the second effect patch to all the instruments (except the drum) and everything became flossy and even the drum was not good anymore. The wave lead will need some chorus and delay but the bass, piano and flute must stay dry. So I guess we only apply effect when it's needed (like they say, if it's not broken, why fix it ?).
Thanks,
Jack Real.
