Old 05-25-2003
fishtop_records fishtop_records is offline
Junior Member
fishtop_records is on a distinguished road
Sonic differences between EQ plug-ins?
are there substantial differences in the sonic quality of
EQ plugins?
I'm currenting running Sonar, had Vegas, and have
CoolEdit, all of which have EQ. Plus
lots of vendors sell EQ plugins. I've never
looked hard at them before, because I had
some that were bundled with the DAW software.
Are there strong differences in sound quality?
If so, who has great sounding plugins that
are "reasonably priced"? And of course,
what is "reasonably priced?"
Is there a EQ that I should plan on buying instead
of that $600 microphone that is on my lust list?
Thanks
Pat http://www.pfarrell.com/prc
Old 05-27-2003
omtayslick omtayslick is offline
1K Silver Member
omtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond reputeomtayslick has a reputation beyond repute
Bump. I also would like to know.
Tom
Old 05-28-2003
JuSumPilgrim JuSumPilgrim is offline
Force of Nature
JuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond reputeJuSumPilgrim has a reputation beyond repute
There is a significant difference between DAW EQs. Generally speaking, of the native EQs, cubase is the most all around musical sounding. Sonar's EQ is basically worthless and Cool Edit's is nice above 1k or 2k, below that I would only use it to cut.
The dif bet EQs has to do with phase relationships.. among other things...boosted/cut frequencies can shift slightly in time in relation to the noncut or boosted frequencies of a given track. This effects stereo image and overall definition in a mix. Significantly. Aside from that, EQs sound dif. The top end on the pultec is not like the top end on the renEQ. EQs crap out in dif ways and at dif frequencies and allow for different degrees of boosts and cuts. Some are better on transients, some are better on a mix, some on individual tracks, some are clinical, some arent. They are definitely not all the same.
Good monitors will come in handy in telling the dif. Download some demos and boost or cut 6dB on any band and move it up and down through the frequency spectrum slowly. Try it on drums, vox, guitars, pianos, etc. Compare and contrast.
EQs I use regularly and think are the shit: UAD-1 Pultec, UAD-1 EX-1, waves renEQ, waves Linear EQ, Timeworks EQ, Ultrafunk EQ.
Old 06-02-2003
toby.I. toby.I. is offline
Senior Member
toby.I. is on a distinguished road
The new Oxford EQ that has been recently been relased is meant to be OK. I haven't used it, but assume it will be similar to the EQ on DMX R100. Pretty stale, clinical, etc but still better than waves!
Old 06-02-2003
c9-2001 c9-2001 is offline
1K Silver Member
c9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond reputec9-2001 has a reputation beyond repute
using the waves Q6 and Q4.. i can make Sx's eq sounds sonically cleaner.. but the Q10 tops it...
JuSumPilgrim
why don't you like the timeworks eq? it sounds great and its real easy to use..i've used it plenty of times..
the UAD-1 Pultec i found to be very clean too.. but i try not to use a lot of eq..
Old 06-02-2003
1K Silver Member
oooppps.. yea he said they're the shit... not Shit..
my bad
Old 06-06-2003
Stefan Elmblad's Avatar
Stefan Elmblad Stefan Elmblad is offline
Force of Nature
Stefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond reputeStefan Elmblad has a reputation beyond repute
All digital EQ suck.
Old 06-06-2003
1K Silver Member
thats cute.. care to explane
Old 06-11-2003
Force of Nature
Sure, it means it doesn't sound any good.
