Old 05-23-2003
gospel gospel is offline
Force of Nature
gospel is on a distinguished road
Hook up new monitors??
I bought some M-Audio Studiophile SP-5B monitors. Can anyone give me some help on how I'm supposed to hook them to my pc? I have two 1/4" cords coming from the monitors that are going to have to go in one 1/8" hole on my pc?????
Old 05-24-2003
morindae morindae is offline
Dedicated Member
morindae is on a distinguished road
Gospel, congratulations on your new monitors, they're a really good deal for the money.
What you can do is get a 1/4" to phono cable. Then connect the cable to a phono to 1/8" adaptor that can be bought at Radio Shack. The adaptor is what goes into the soundcard. You should be up and running in no time. You're going to love the difference. I hope you enjoy them.
Old 05-24-2003
Force of Nature
I'm supposing by 'phono' you mean rca? I understand everything you are saying except it still sounds like I'm gonna end up with 2 1/8" cords that need to go in one hole on my pc???
Old 05-24-2003
Dedicated Member
You'll be ok because the rca to 1/8" adaptor is a two into one. So both the cables from the monitors go into the adaptor, and from there straight into the line in on the soundcard.
Old 05-24-2003
Force of Nature
I must be having an off day I'm usually not this stupid. Ok let me run this down. When I go to Radio Shack I need to get a cord that has 1- 1/8" stereo plug on one end and 2 male rca plugs on the other end. Then I need to get 2 cords that have 1- 1/4" stereo plug on one end and two rca female plugs on the other end. When I get it all hooked up I will have one of the female rca plugs on each of the cords that nothing is hooked into? Just wanted to make sure before I went to Radio Shack.
Old 05-24-2003
bdbdbuck's Avatar
bdbdbuck bdbdbuck is offline
1K Silver Member
bdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond reputebdbdbuck has a reputation beyond repute
Gospel,
Sorry I didn't explain good enough...I'm bad about that. The adaptor I have is 1/8" stereo with 2 RCA Female plugs, I don't think they make one with Male. The RCA plugs are going to be MONO. But like I said in the e-mail, in your case maybe you would be better off with 1/8" Stereo male plugged into your computer that adapts to (2) 1/4" MONO female plugs for your monitors to plug into since your monitors already have the cables with 1/4" male plugs.
bd
Old 05-24-2003
Force of Nature
Originally posted by bdbdbuck
Gospel,
bd
It's not you, it's me. I'm no genius, but I can figure out a lot of things. I taught myself computers, live sound equipment, electronics repair (some), and numerous other things, but I always have trouble hooking anything up??? I have a learning disability when it comes to hooking up anything. I can repair the motorola radios that we have in our vehicles at work, but I can't install one???
Also, there is one thing I didn't comunicate right about. The monitors have XLR and 1/4" hookups, but no cords.
Old 05-24-2003
Dedicated Member
Gospel now you've got me confused. I am of course describing my own method of connection which is also with a Behringer mixer. I am using 1/4" to phono (rca) cables because they were what I had in my supply box.
First let's look at the adaptor; imagine a 'Y' with a piece of black, square shaped plastic over it, and out of one end of the black square projects the bottom end of the 'Y'. This is the part that goes into the computer. The cables from the monitors will go into the holes at the top end of the square which is where the two arms of the 'Y' are. So here we have a two into one adaptor. My adaptor is rca into 1/8". So coming from the monitors, I have plugged into it cables that are 1/4' to rca. It is probably possible to get an adaptor that goes from 1/4" to 1/8". I haven't looked because I had these phono to 1/4" leads and used them instead.
I hope I haven't confused you even more. You could of course call M-Audio and let them recommend something. I'm sure they'll have an answer for you. I hope this helps.
Good luck.
Old 05-24-2003
bdbdbuck's Avatar
1K Silver Member
OK, your monitors have the same type hookups mine do. I have those little inserts that are 1/4" mono male on one end and RCA on the other end plugged into the 1/4" jack in my monitors, and the RCA cable plugged into them. That works out with the 1/8" stereo to RCA adaptor at the computer.
bd
Old 05-24-2003
Force of Nature
I GOT IT!!!!! YIPPEE!!!! I GOT IT!!!!
Old 05-25-2003
Dedicated Member
Yeah bdbdbuck, I guess we are doing the same thing. By the way, how are your M-Audio monitors?
And Gospel, I can't wait to hear what you think of yours. I was truly amazed the first time I plugged them in. I was recording an acoustic guitar piece and the playback was magnificent compared to what I had before. It was almost like there was someone in the room playing the guitar, it was that clear. Also, it makes a huge difference when you download mp3's of peoples work.
  #12
Old 05-25-2003
Force of Nature
I am going to Radio Shack in a bit and get what I need to hook up the monitors. Just wanted to ask those of you who are using monitors about placement. I've heard a big deal made of this on other forums. The manual says that the top of the woofer should be at ear level. Just wondering if any of you experimented with placement?
  #13
Old 05-25-2003
bdbdbuck's Avatar
1K Silver Member
Morindae,
I can't decide if I like em or not....they make ALL my old recordings sound like crap! Makes me wish I'd had them long ago, before I made those recordings. I'm still learning so it's just the next natural step to take I guess. All said, I love em!
Gospel,
I have mine under the desk where I have my computer...wish I had room on top, they still sound 100% better than my computer speakers.
bd
  #14
Old 05-25-2003
Dedicated Member
I hear you bd, I'm still learning about mine as well. I bet we grow out of these real soon. This hobby is a bottomless pit of spending.
Gospel, I have mine at ear level. I put them either side of the computer monitor pointed in towards me, which, if my memory serves me right, is the way the manual recommends. My chair is adjustable so that I can get lower if I need the tweeters right at ear level. You'll be amazed at how uncolored they are. I had to go and tweak all the amp models in my POD when I got these speakers, mostly to add some top end on the settings.
  #15
Old 05-25-2003
bdbdbuck's Avatar
1K Silver Member
I can relate to the bottom end being way out of control.....my stuff was boomy beyond belief.
bd
  #16
Old 05-25-2003
bdbdbuck's Avatar
1K Silver Member
Oh, and the spending........... ??? ...........where does it end?
bd
  #17
Old 05-25-2003
Force of Nature
spending
You guys are right about spending. I bought the monitors and don't even have them hooked up yet (fell asleep and didn't ever go to Radio Shack) and am already thinking about a condenser mic and a Berry UB series mixer.
  #18
Old 05-26-2003
Dedicated Member
Gospel, I have the Behringer UB 802 which I am quite happy with. I actually prefer the preamps on it to my audio buddy. The drawback with the mixer is that it is noisy and tends to suck the tone out of my POD. However, with the MXL V67G, it actually works quite well. I don't like the V67 with the audio buddy, it tends to be a bit harsh for my taste. I get the impression from some of the posts I've read that the Studio Projects B1 works better with the audio buddy. If I could buy again I would probably go with the B1. In fact, my next microphone will be the B1 because I want something that can record acoustic guitar and double up as a second option for vocals. I intend to stay with this setup for a while until I get my recording chops down. For the future, I am planning on building a computer that will be dedicated to audio only. This will cut down on the amount of cables and peripheral stuff that clutters up my limited space. This is a very obsessive hobby and I think it makes sense to put yourself on a yearly budget for new gear so as not to let it get out of control.
You may want to check out a good low end preamp (SP VTB 1 or M Audio DMP3 etc) instead of the mixer if you are only putting vocals into the MR 8.
By the way, what are you using for backing tracks?
  #19
Old 05-26-2003
Force of Nature
I'm using pre-recorded soundtracks that are mostly on CD. That is why I don't post any songs on nowhereradio because I don't have the recording rights to some of the tracks. It's a bummer sometimes to not be a musician. I've went through the whole thing on two different projects with our group of contacting publishers and getting license to record songs. In twenty songs I've had two publishers who actually wanted royalties. But, we must go by the nowhereradio rules. I have thought of getting some of the great musicians on here to make some tracks for me.
As for the Behringer mixer. I read a review of low end pre-amps on the n-track forum on the fasoft site. The guy tried out numerous pres and said that the Behringer UB series preamps are good. He also liked the Audio Buddy. I think the UB802 is what I've been looking at on MF for $69.99. When it comes to mics, the studio projects B1 is at the top of my list along with the MXLs. Just don't know what MXL to look at. I'll never be recording anything with them except vocals.
  #20
Old 05-26-2003
bdbdbuck's Avatar
1K Silver Member
Gospel,
Courtney has the MXL 93 I think. It sounds so good with her voice, I was thinking I would have to have one. My A-V cobalt worked pretty good with the last song I recorded, at least I think it did. I got it used for $40 at a local music store. If I was going to buy another condenser mic, I would go with a large diaphragm.
As far as mixers go....I use the Behringer UB1002 and I love it! The only time I get any noise out of it is when I have the gain cranked too high. The nice thing about the Behringers is the Phantom power, something you wouldn't really expect for such a low price.
bd
  #21
Old 05-26-2003
Dedicated Member
You know bd, I am almost ashamed to admit I own a Behringer mixer, they get such negative reviews and comments on these forums. However, when you actually get comments from regular joe's like ourselves, you find that they are actually incredible bang for the buck. I guess if you aspire to recording on a Neve desk then a Behringer is just a joke. For me, the mixer was an excellent buy. As far as the noise issue is concerned, I have experienced a lot of noise when attempting to record acoustic guitar, and yes, I had the gain cranked. However, when I did the same thing on the Audio Buddy pre amp it was silent. But what the hell, for eighty bucks what can I expect.
Gospel, I have the same issue myself. I am recording a blues album, all covers of course. It's a project I have always wanted to to and it''s a good excuse to do a lot of guitar playing and singing whilst at the same time learning how to record. The one problem is posting. Like you, I cannot do the nowhereradio thing. I guess what some of us in this position could do is send mp3's via email for others to comment on. By the way, just buy the B1 and put yourself out of your misery. By this time next year you know you'll have a couple of MXL's along with it.
  #22
Old 05-26-2003
Force of Nature
Got the monitors hooked
Man what a difference. There is only one problem. I want to re-mix every song I have on my pc. I guess I'll save it for the next project. According to how accurate these things are my other mixes are very harsh and need a good bit mid lows or lows (can't really tell which one right now). These things are great. They may not be Mackies, Genelecs, KRKs, or any of those others that are made out of gold.
By the way, don't know if I told on this thread about the deal I got. They are M-Audio Studiophile SP-5Bs. I caught them on musician's friend on the scratch and dent page. One of them has a scratch on the bottom of it. $159.99.
  #23
Old 05-26-2003
Dedicated Member
Very sweet Gospel, you can't go wrong with that one. Congratulations. Now we just have to get to know the monitors so that our mixes are good on all types of systems. That will take time, but we have enough to work with. I'm still learning about mine and find it very useful to listen to albums on them so that I can get a feel for where things should sit in the mix. This is really useful. Again, you did really well to find that deal.
  #24
Old 05-27-2003
bdbdbuck's Avatar
1K Silver Member
Very good deal indeed, MF just put them ON SALE for $200! In my case, the monitors are the best speakers in the house so all the cd's get played on the computer now. It does give you a reference to an extent, problem is comparing acoustic guitar and vox to a full blown production.
The Behringer thing........that mixer was the first piece of equipment I bought, when I was recording on the computer. I spent a lot of time researching, which didn't really help a lot. In the end, the price was the deciding factor. I don't regret the decision I made, in fact I question the wisdom of spending multiples of what I spent for..... :??? what?
bd
  #25
Old 05-27-2003
Force of Nature
I will be buying probably a Behringer UB802. I think it is the one with two mic inputs for $70 or $80 and a condenser soon. I just wish that musician's friend had the Studio Projects B1? I like buying from them. I already have an account with them and get 90 days same as cash. I might just have to start out with a mic that they carry.
