Go Back   Home Recording > User Forums by Brand > Cool Edit Pro / Adobe Audition Forum
Reply    Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 05-21-2003
jwgeetar's Avatar
jwgeetar jwgeetar is offline
Dedicated Member
jwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond repute
setting up CEP with a audiophile 24/96?
yea, does anyone have any links to setting up CEP with my delta card? the m-audio site has a bunch of software setup manuals but not with CEP.thx jw
Beauty is in the eye of the Beerholder-jw weir
http://jwweir.com
Old 05-22-2003
rats's Avatar
rats rats is offline
Ikantre Member
rats has a reputation beyond reputerats has a reputation beyond reputerats has a reputation beyond reputerats has a reputation beyond reputerats has a reputation beyond reputerats has a reputation beyond reputerats has a reputation beyond reputerats has a reputation beyond reputerats has a reputation beyond reputerats has a reputation beyond reputerats has a reputation beyond repute
The trick is getting your card set up first. I'm using one of those and had all kinds of weird problems getting it going. Make sure you have the most current drivers, or even a version or two back I have heard is preferrable. It depends on what type of system you are running, but assuming you use an external mixer for your input device, and some type of monitors, I have had the best luck with setting up the monitor mixer to choose my input as H/W in 1/2 and the output as H/W in 1/2. Make sure your volumes are up all the way and selected (not muted). Make sure you go into your PC control panel into sounds, preferences, and choose the M-Audio card as your preferred play back AND recording device. At this point you should be getting play back and recordablity. In cool edit you'll need to go into options - preferences - and set your default record and playback devices to M Audio H/W in 1/2 (both playback and record). I've used the M-Audio delta monitor mixer selection as well, but got better performance with the H/W in 1/2.
The problem I had when I first installed the card was it was acting like it wasn't a full duplex sound card; I couldn't play back and record at the same time, only one or the other. If you run across that- it's not true! You just have something not selected right.
Old 05-22-2003
jwgeetar's Avatar
Dedicated Member
thanks rats. yea i had it working before in win2k with N-track but i went xp for a while now it's back in win2k. i get playback in CEP but the recording option is not there. i'm at work now so i cant look at it. i need to double check the m-audio control panel---forgot about that one. although in device preferences in CEP, i see the H/W in 1/2 availability. hmmmm! ok,thx again--- i'm just boning up for attacking it tonight.
http://jwweir.com
