Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 05-16-2003
czar of bizarre czar of bizarre is offline
Dedicated Member
czar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these partsczar of bizarre is infamous around these parts
Thumbs down pro tools midi DOES suck!!!! someone please help!!!
ok guys heres the deal. im working with someone and im trying to help them configure the digi 001 and use it via midi. i use cubase sx,vs880ex,dr 660, um 2 midi box and xp60 for midi. my friend uses a digi 001,proteus,mpc,midi controller and midi sport midi interface.
i tried to connect his gear as if it were my set up. but i DONT know how to operate the midi in pro tools. i dont know what to click and i have scrolled hundreds of screens. well to make a long story short this is how i wanna set it up.
i want to use pro tools as the *master* and everything else as slave. i want to be able to play the proteus through the midi controller. i want to press play on pro tools and have the mpc play back. everything needs to be hooked up.
i need instructions on the pro tools OMS set up. i dont see a "sync" page where i can select midi clock etc etc etc.
if this thread seems rushed or in haste its because it is. as soon as i finish this i need to get back to busting my brain.....
the mpc has 2 midi outs and two midi ins. the digi has midi in and out. the proteus has in and out and so does the midi controller. the midi interface has two ins and two outs.
someone help. thanks in advance.excuse all typos,caps are not meant as yelling,this message will also appear in the computer recording section.
the czar
ps the pro tools manual said to NOT hook the digi midi *directly* to the interfcae midi.....
Old 05-18-2003
Dedicated Member
i finally got it to work. thanks for the replies.
czar
Old 05-23-2003
James Argo's Avatar
James Argo James Argo is offline
Fancy Rock N' Roll
James Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond repute
Look, I don't mean to offens your post. But as a new member you should know the culture of the BBS...
1. DO NOT start a thread with insult (s**k, F**k, etc).
2. DO NOT cross post (Post the same subject & words in several forums on this BBS).
No, there's no formal rule about it, but you won't get any attention by doing so. And you're lucky if no one start bitching you. Just ask nicely, and most of us will be very friendly to help you out. Hope it helps.
Jaymz
Keep Rockin' and Rollin'...
Old 05-23-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Lol, check the dates. He's been here longer than you
Old 05-24-2003
James Argo's Avatar
Fancy Rock N' Roll
Thumbs up
3. DO check the dates before posting any comments...
...okay... okay... my bad
Old 05-24-2003
moskus's Avatar
moskus moskus is offline
The Creator of Æ, Ø and Å
moskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond repute
And he is not a newbie, he's a "Dedicated Member"...
Two wrongs don't make a right, but two Wrights once made an airplane...
