Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 05-15-2003
SOUND DIAGNOSIS's Avatar
SOUND DIAGNOSIS SOUND DIAGNOSIS is offline
Dedicated Member
SOUND DIAGNOSIS has a reputation beyond reputeSOUND DIAGNOSIS has a reputation beyond reputeSOUND DIAGNOSIS has a reputation beyond reputeSOUND DIAGNOSIS has a reputation beyond reputeSOUND DIAGNOSIS has a reputation beyond reputeSOUND DIAGNOSIS has a reputation beyond reputeSOUND DIAGNOSIS has a reputation beyond reputeSOUND DIAGNOSIS has a reputation beyond reputeSOUND DIAGNOSIS has a reputation beyond reputeSOUND DIAGNOSIS has a reputation beyond reputeSOUND DIAGNOSIS has a reputation beyond repute
Sequencing/indiv. track recording quest.
Would I derive more of a benifit from laying down tracks of a composition from a synth separately track by track in a multi-track recording environment, or just loading a sequence already mixed and panned into a stereo track? I imagine the former is the way to go. I am sure someone has an answer to this elementary question. Could you throw in an explanation as to why your choice would be the way to go as well? Thanks ---LEE
Having children is like being pecked to death by chickens.
Old 05-16-2003
shackrock's Avatar
shackrock shackrock is offline
1K Silver Member
shackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond repute
track by track allows you to still mix whatever it is even further with anything new you will be reording, so i go with that. sound wise, if you were to mix it no different then the latter, then i see no difference. but i suspect you will.
and i also take it that you're talking about one element (perhaps a beat), that you can put vox or some live instruments too..right? haha.
Scott Solo
Old 05-16-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Track by track gives you the greatest flexibility and sound quality.
Old 05-16-2003
Dedicated Member
Dear Spammis Prolificus (TEX),
I thought so. Thanks for the confirmation.
The problem I forsee is that this tiny "buzz" I hear when recording ONLY when I line input my stuff from the synth to the line in on my soundcard. I would imagine 10 tracks of this VERY low level buzz would cause a problem. Funny, NO problem with micing, only my synth. Signal is clean....squeaky clean, coming out of my synth. All lines are going into the same outlet (APC UPS)......doesnt sound like a ground loop hum...it is more of a buzz.....I have to diagnose this sucker. Maybe I am using a cheapo 1/4>1/8 adapter. Could that be it?? Any ideas, you all???? Thanks in advance ~~Lee
Old 05-16-2003
Audio Bum
That would be a problem. Check the cables and also plug all connected gear into power strips originating from the same wall outlet. You can also buy some ground lift plugs (3 to 2prong convertors) and add them to some of the gear to try and eliminate the buzz.
Old 05-16-2003
Dedicated Member
Hey Tex....is a groung loop hum ALWAYS a hum??? This is a distinct low-level electrical buzz. Could this buzz be a ground loop problem in your experience??? Thanks for the help....again....dude! ~~~Lee
Old 05-16-2003
Dedicated Member
That 3 prong to 2 prong isn't exactly orthodox. Can it be dangerous to my health? :O\
