Originally posted by dafduc
Are you saying you re-initialized?
If it's still doing it (and you re-initted with the pitch bend and mod wheel in their home positions) you may have a sreious problem. I had one expansion card go bad like that, but not the whole unit.
Daf
Yes, I re-initialized, and both the pitch bend and mod wheel were in their home positions. It had been working fine, except that after I'd had it connected to my PC sequencer I couldn't get anything to play in the Mix mode (the Program mode still worked fine). So I re-initialized ... and that's when I noticed the pitch shift effect. I haven't checked every Program/Mix, but it does seem to be a "global" problem. I play a chord and it sounds like it goes out of tune the longer/harder I press the keys.
Could I have inadvertently applied a pitch shift effect to one of the MIDI channels, so that every Mix/Program using that channel processes that effect?
