Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 05-12-2003
umair umair is offline
Senior Member
umair is on a distinguished road
Help installing pickups and my volume is acting strange
Hi.
I am trying to install Zakk Wylde pickups in my guitar.
These are the EMG85/87 set of active pickups. This is the third time I am installing pickups in a guitar so by no means do I know what I'm doing.
I am no expert at this but have done a good job previously.
However, I have wired everything for this one guitar right in front
of me and the volume was acting strange.
When its in the off position I still hear faint string noise. When it at the max position it totally cuts out. When it's in the middle the sound is awesome. What the hell am I doing wrong I t hought? Nothing I answered, I'm good. It must be the pot. They give you tons of extras so I replaced it. Nope. Same problem. I'm thinking I fouled up a connection or something. I can't figure it out. Maybe I'm shorting out somewhere.
Anybody know what I'm doing wrong. My soldering iron is still hot and I really want to end this project. I have been playing it with the volume in the middle for about 2 months now. IT sounds awesome. I always thought it was a bad pot but it doesn't look like that's the problem.
Thanks.
Old 05-12-2003
PFDarkside PFDarkside is offline
Senior Member
PFDarkside is on a distinguished road
What is the resistance of the pot? (It's the "ohms" number, maybe the greek letter Omega) For EMGs it must be somewhere around 25K ohms, not 250K or 500K. How are you wiring it? Is it in a Les Paul style guitar? If so, do you want one volume control to be able to act as a "master" when it is at "0" or would you like to keep them totally independant?
(Also, the Wylde set is an 85 for the neck and an 81 in the bridge)
Old 05-13-2003
Clive Hugh Clive Hugh is offline
Force of Nature
Clive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond repute
Just a thought, did you earth the thing because I recall that some EMG's do not allow for earthing, check the instructions, I have come accross it before.
Old 05-13-2003
Senior Member
Good point, all EMGs are internally grounded...
(So basically, are you using all EMG components, are you using an EMG circuit and what is the control style of your guitar)
Old 05-13-2003
Senior Member
I'm using all the proper components. I'm using what came in the box. The only thing that is stock is the 5 way switch and the middle single coil pickup.
It's an Ibanez S470.
Old 05-13-2003
TheGuitarMan's Avatar
TheGuitarMan TheGuitarMan is offline
Dedicated Member
TheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond repute
That single coil isn't passive, is it?
Old 05-13-2003
Senior Member
crap.. yeah it is... I bet you are going to tell me that you can't wire the passive with the actives without draining battery or something.
I don't ever use it so I don't care if I disconnect it. Is that my problem?!
Old 05-13-2003
Senior Member
Try disconnecting it. It *may* work. If it does, I'd go with a 3-way switch to have better functionality. (Or connect the bridge to 1 & 5 and the neck to 3. Then you get: Bridge, B&N, N, B&N, B.)
Old 05-13-2003
Senior Member
Nope.
Didn't work.
Still can't figure it out. Both pots can't be bad can they!? I'll keep tryin.
Old 05-13-2003
Senior Member
Do you have/have access to a multimeter? That will verify that the pot is good. Do you still have the bridge ground connected?
Old 05-13-2003
Senior Member
Bridge ground is connected.
Going to borrow a multimeter from work tomorrow...
Thanks for all of the suggestions.
Will let you know tomorrow.
  #12
Old 05-14-2003
Force of Nature
PFDarkside,
Shoulden't he disconnect the bridge ground too?
  #13
Old 05-15-2003
Senior Member
Yes, that's what I was getting at. I'm not sure that it will work (not to familiar with EMG) but I know they are advertised as internally grounded and not needing a physical ground on the guitar.
  #14
Old 05-18-2003
Senior Member
Disconnected the grounding wire fromt he bridge.
No dice.
I still don't have the multimeter.
