Snapping Property...bad work flow
is it just me that it takes up alot of time to switch back and forth between the snap properties?
say, I am trimming a loop, I set the snap to be 1/32 measure, trim it, and then I gotta zoom out to find the other loop I wanna connect to, then switch the snap property to 'snap to clip boundry' (cuz sometimes Sonar just doesn't do that "click"), then I gotta zoom back in to make sure everything was connected properly. I mean, everything works, but just takes up so much time!! Can't Sonar work like ACID where everything falls into a grid?? So I don't have to switch the snap property just to trim the loop cuz it doesn't snap at the end of each loop Al |
Just hit Shift+N, it's much easier...
Oh! And you can turn the snap on and off by hitting N...
Two wrongs don't make a right, but two Wrights once made an airplane... |
you are a life-saver!
Al |
Thank you!
![]() Can I quote you on that? ![]()
