Old 05-03-2003
tjohnston's Avatar
tjohnston tjohnston is offline
Milf Hunter
tjohnston will become famous soon enough
Question Everything hisses... Why?
Seems like everthing I listen to has faint hiss. Doesnt matter if its mp3, radio, tv, or CD. If you listen closely you can hear that hiss. I have heard people talk about digital medium as being a hissless format. Where does this hiss come from? Is it the cd player, speakers, wires airwaves.... what is it? Even on professionally recorded storebought cd its still there. Seems like the older music for instance, Led Zepplin has louder hiss. In gerneral everything just hisses.
Old 05-03-2003
Stealthtech's Avatar
Stealthtech Stealthtech is offline
LOGIC ABUSER
Stealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond repute
On every CD player you listen to.
Old 05-03-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
It just is....!
Old 05-03-2003
LOGIC ABUSER
Originally posted by Blue Bear Sound
It just is....!
It jusssssssssssssssst issssssssssssssssssss
Old 05-05-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Re: Everything hisses... Why?
Every piece of gear has a signal to noise ratio and the lowest spec'd link in the chain will cause the hiss. To troubleshoot it start at the end (power amp - speakers) and work to the front (CD player). Dirty power can even cause extra hiss. Crank up you power amp/monitors with nothing plugged in and that is the most quiet your chain will ever be. It's all down hill from there.
Better gear = Less hiss. We don't diss cheap gear because we are snobs. We diss cheap gear because among other problems they usually have a lot of hiss.
Old 05-05-2003
Track Rat's Avatar
Total Gear Slut
Everything generates self noise. Some devices much more than others.
Old 05-09-2003
The Green Hornet The Green Hornet is offline
Been Here, Posted That
The Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond repute
Talking
Yo You can calls me Johnson:
You will get a higly integrated hiss if you are using a snake.
Sorry, I couldn't resist!!
Green Hornet
Old 05-09-2003
MISTERQCUE's Avatar
MISTERQCUE MISTERQCUE is offline
Not Just Anutha Brutha
MISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond repute
My "canned drum" machine, Boss DR202, also introduces an inordinate amount of hisssssssing during tracking.
I tried hi-filtering and upper freq eq cut, adj'ing volume etc and nuthin' seemed to work.
I have a 3630 which I prob'ly used maybe 3 times in 4 years
and decided to connect the 202 into the 3630 and incorporate the unit's GATE function figuring that since gates are also used to cut the tail end of a signal's length and control decay and resonance somewhat ('specially on 'Verbs), I found an effective way to eliminate 80% of the hiss produced by the 202 by gating the "hits" and FINALLY finding a use for the 3630 (since I couldn't even sell the d@mn thing for $25 and a ham & cheese samich)!
Old 05-10-2003
mixsit mixsit is offline
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
How about this?
If you focus enough, there IS hiss everywhere.
Some of the source is external to you -in recordings, anything electronic or just background noise. But that noise can, in many cases be below audible or masked by the program material.
So that leaves you. You're noise.
I believe if you listen closely enough, you will find it. Or if you look closely enough, it's there also.
I suppose it might just be one of those focus=scale=zoom factor thingys.
Or not.
Wayne
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Old 05-11-2003
Kevin Blight's Avatar
Kevin Blight Kevin Blight is offline
Newbie
Kevin Blight is on a distinguished road
Sun spotssssss.....
Old 05-11-2003
Toker41's Avatar
Toker41 Toker41 is offline
Better Than You
Toker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond repute
Damn, I have a couple of those 3630's and I get more noise from them than any other gear I have. Infact my alesis Quadraverb is has a bit more noise. I use to be a fan of Alesis, now I can't seem to remember why. Do they make anything that isn't full of white noise?
