Go Back   Home Recording > User Forums by Brand > Alesis Forum
Reply    Audiofanzine Alesis Alesis News Alesis Medias Alesis Tests Alesis Articles Alesis User Reviews Alesis Classifieds Ads
Old 04-19-2003
hasbeen's Avatar
hasbeen hasbeen is offline
Dedicated Member
hasbeen is on a distinguished road
Masterlink Tutorial?
Is there any literature or a tutorial that can walk me through typical settings used in mastering? I have a Masterlink and am using it for mixdown in my home studio. Not for release, mind you, but for my own songs. I am familiar with the functions ie eq, comp, normalizing by name but the manual does not go into detail about a typical mastering session. Would love a book called mastering for dummies!
Old 04-19-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Re: Masterlink Tutorial?
Won't happen.... mastering is an involved process that takes a lot of skill and experienced listening - plus a hugely expensive critical-listening environment...
Go to Bob Katz's site - a number of good articles to help you understand the process though... http://www.digido.com
Old 04-19-2003
AEL AEL is offline
Junior Member
AEL is on a distinguished road
A lot depends on the type of music you have recorded. What is it, and how many mixdown tracks? What instruments, vocals, etc. Any effects added to the tracks already? Please reply, and I will try to help. The most important question is, though, is anything wrong with it before mastering, or is it just fine as is? If nothing is wrong, don't screw it up. If you can identify the problems, you are well on your way to fixing them. Yes, big studios have lots of expensive gear and talented, trained people. Home recordists often do not, an are required to muddle through as best they can. I mastered my CD by listening to it through regular old living room speakers. It seems to sound great on all other systems I've tried it on. Lots of compliments from the people who bought it, even if it's not in the same league as the pros. Then too, some of the "pro" stuff sounds like over-processed crap to my ears. Matter of opinion. Al
Old 04-20-2003
hasbeen's Avatar
Dedicated Member
My questions are probably specific to the Masterlink, but I am wondering what the typical settings would be for compression, eq, normalizing etc on this machine for a tune that is already decently mixed?
Old 04-20-2003
AEL AEL is offline
Junior Member
Already decently mixed? Then maybe you don't need any of the dsp you mentioned. The limiter might help you, though. Try this: set the level meter to hold the highest peak, then play the tune. Make note of the highest peak. Then set input gain to boost overall volume so that the highest peak will be around -4db. Then, activate the limiter, set the max output level to 0db (which is the default), then run the threshold down to a level that makes the music sound better as you are listening to it. Keep running it down until it sounds worse (all volume loud and the same level), then back up again until you get it just right. It will probably be somewhere around -5 or -6. You probably won't need to use any other dsp. Try it, and let me know how it works for you. Al
