Go Back   Home Recording > User Forums by Brand > Alesis Forum
Reply    Audiofanzine Alesis Alesis News Alesis Medias Alesis Tests Alesis Articles Alesis User Reviews Alesis Classifieds Ads
Old 04-14-2003
werewolf831 werewolf831 is offline
Senior Member
werewolf831 is infamous around these partswerewolf831 is infamous around these partswerewolf831 is infamous around these partswerewolf831 is infamous around these partswerewolf831 is infamous around these parts
16 bit ADAT tape soundng better than 20 bit tape?
I've had to use a 16 bit adat tape recently, and it seems to me that when I mix down to a wav file, the mixes made from the 16 bit tapes sound a little better than the 20 bit. I can especially hear this in the cymbals, they seem more clear and realistic. I'm wondering if my setup has anything to do with this. I record on an LX20 and use a Mackie 1604vlz. I mixdown to my computer soundcard (audiophile 24/96) rca line in from the rca tape out on the back of my mixer.
I'm wondering if by going from a 20 bit tape to a 16 bit wav file, I'm losing some sound quality, and maybe my signal is more pristine with the 16 bit tape. Could somebody tell me if this is possible? Or maybe I'm just hearing things.
Thanks
Old 04-14-2003
Track Rat's Avatar
Total Gear Slut
You're doing an analog mix down. You're probably hearing the "rounding off " of the mix from the analog mixer and whatever character the A/D converters in the soundcard imparts. That's the main reason I mix that way.
Old 04-15-2003
Senior Member
"That's the main reason I mix that way."
I'm not following you Track Rat. Is it bad for the "rounding off" to occur? What kind of tapes are you using, 20 bit or 16?
Old 04-15-2003
Track Rat's Avatar
Total Gear Slut
I think the rouding off is a good thing in my opinion. It can kind of "pull" a mix together.
By the way, when I use ADATs it's 20 bit/ 44.1k.
Old 04-15-2003
Senior Member
Don't you think that can be done in the mixdown though? Are you concerned with any loss of sound quality?
thanks TR
Old 04-15-2003
Senior Member
whoa, I just noticed something about your post. I though all Adat tapes were pre formatted to 48 k?
Old 04-15-2003
Track Rat's Avatar
Total Gear Slut
ADAT tapes that I use don't come preformated (S-VHS tapes like Quantigy, HHB, etc).
Old 04-15-2003
sweetnubs's Avatar
sweetnubs sweetnubs is offline
Force of Nature
sweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond repute
don't use preformatted tapes for your ADAT's. You want the tape to be formatted by the machine it is going to be played back in for optimum signalation integrityation. thank you.
Old 04-15-2003
Senior Member
Ok, but can a tape you format on your machine be played on any other machine? And also, any particular reason to record at 44.1k as opposed to 48?
Thanks
Old 04-16-2003
sweetnubs's Avatar
Force of Nature
sure you can play tape on any machine regardless of which one formatted it. You get better quality playing the particular tape formatted on a particular machine. If you are mixing analog I'd record at 48k, If you are mixing digitally i'd go with 44.1 so you don't have to resample/truncate from 48k to 44.1, unless you are mixing to analog then i'd go with 48k. hello to you, does this make sense?
Old 04-16-2003
Senior Member
Makes more sense. Thanks guys.
  #12
Old 04-16-2003
sweetnubs's Avatar
Force of Nature
let me clarify my last post a little since I reread and it seems a little confusing. If you are using an analog mixer go 48k regardless if your two track deck is digital or analog. If you are using a digital mixer/DAW and transfering tracks digitally and mixing down to a digital deck through digital connections, i.e. the chain is entirely digital, then go 44.1 to avoid resampling/truncation. If you are mixing digitally but your mixdown deck is analog then go 48k. dig?
  #13
Old 04-16-2003
Senior Member
I'm mixing with an external mixer, mixing to my pc through the rca jacks, so I suppose I am mixing in analog. All my adat tapes are at 48khz, so guess I'm doing all right there. Your second post made even more sense, much thanks. I'll be recording for the next couple days now...using 20 bit tapes. Although that 16 bit tape was sounding damn good after mixdown...
