Go Back   Home Recording > User Forums by Brand > Cool Edit Pro / Adobe Audition Forum
Reply    Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 04-14-2003
ZEKE SAYER's Avatar
ZEKE SAYER ZEKE SAYER is offline
Being a virgin sucks
ZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond reputeZEKE SAYER has a reputation beyond repute
Need info on CEP 2
I saw that Cool Edit Pro 2.0 can record 128 tracks. Well, my computer has a pentium 3 processor (i think it like 667mhz ), 196mb or ram and a 10gb hard drive with windows ME. How many tracks do you think that i can record before it starts droping-out and frezing up and stuff. And what are the diffurent things in cool edit pro 2.0 that cool edit pro 1.0 don't have? Does cool edit pro 2.0 have all of the things that cool edit pro 1.0 has?
Thanks,
Zeke
"I will make your hair turn gray!"
Old 04-14-2003
scottboyher's Avatar
scottboyher scottboyher is offline
The King Of Nothing
scottboyher will become famous soon enoughscottboyher will become famous soon enough
http://homerecording.com/bbs/showthr...threadid=81533
_______________________________
www.scottboyher.com
info@scottboyher.com
Old 04-14-2003
ZEKE SAYER's Avatar
I don't really need to know how many tracks you can record at the same time. I record all my audio on my Fostex Vf16 and because the eq and effects suck on it, i'm gonna start sending the clean audio from my vf16 to my computer via scsi and mix and edit them in CEP 2. I was wanting to know, how many tracks could your record, compress, revurb and eq before the computer starts droping out.
Old 04-14-2003
The King Of Nothing
Well I am still using a Pentium II at 433, 10 gig drive and Windows 98SE. I have not had a problem so far only recording 25 or so tracks. It does go a bit slow with more tracks but it gets the job done. The only real problem I have had is the real time effects tend to really be processor hungry. Cool Edit 2000 has only 4 tracks so you would be better off to get Cool Edit 2.0 or 2.1 now.
www.scottboyher.com
Old 04-14-2003
ZEKE SAYER's Avatar
[QUOTE]Originally posted by scottboyher
[B]The only real problem I have had is the real time effects tend to really be processor hungry.
What do you mean by that?
Old 04-14-2003
The King Of Nothing
Well CE2.0 allows for real time effects to be added to the tracks with out acually changing the original wav files.
www.scottboyher.com
Old 04-14-2003
ZEKE SAYER's Avatar
I know that this sounds dumb but what is the diffurents between
real time effects and effects?
Old 04-14-2003
The King Of Nothing
Well the real time effect thing is applying the effect as you are playing the tracks but it doesn't make any permanent changes to the .wav file itself and can be removed at any time.
You could also go to the tracks one by one and add an effect in edit view but that is physically altering the .wav itself. That effect would be permanent after you close and save your session.
www.scottboyher.com
Old 04-14-2003
ZEKE SAYER's Avatar
Well, like i said, i would be uploading my tracks from my vf16 into the computer and then adding effects later, so i don't think that i will have to worry about that.
ZEke
Old 04-14-2003
Tukkis's Avatar
Tukkis Tukkis is offline
The Wonder From Downunder
Tukkis has a reputation beyond reputeTukkis has a reputation beyond reputeTukkis has a reputation beyond reputeTukkis has a reputation beyond reputeTukkis has a reputation beyond reputeTukkis has a reputation beyond reputeTukkis has a reputation beyond reputeTukkis has a reputation beyond reputeTukkis has a reputation beyond reputeTukkis has a reputation beyond reputeTukkis has a reputation beyond repute
Zeke, what he means by real time effects is say you wanted to have reverb on you snare track in Cool Edit Pro.
You could either select the snare track and apply the reverb in the edit mode in CEP or...
you could place the reverb on the track in multitrack mode which doesn't actually affect you original snare track
With the first method after you apply the reverb and save the file and exit you can't come back later on and change the type of reverb or take it off unless you had save a dry snare track somewhere else.
The second method which is real time effects lets you come back later on and allows to change the reverb that you put before or turn it off if you don't like it, all the while leaving you original snare track untouched.
You actually will because you will be uploading dry tracks from your fostex and then you will have the choice to either apply one of the two methods mentioned above for effects.
Have Fun
Tukkis
Old 04-15-2003
ZEKE SAYER's Avatar
So, is real time effects like a effect bus with sends and stuff. that's how my vf-16 is.
  #12
Old 04-15-2003
Tukkis's Avatar
Yeh pretty much.
It's like have AUX sends or effects sends on each channel. This means you can send the signal to the effects. You can even adjust the order of the effects.eg compressor 1st, reverb 2nd
Tukkis
  #13
Old 04-15-2003
ZEKE SAYER's Avatar
Well, Scottboyher's Computer is a P. 11 and myne will be a P. 111 so, maybe it won't effect the real time effects when i record a great number of tracks. i don't thing that i will record over 24. but incease i have to, the're there if i need them.
  #14
Old 04-15-2003
Tukkis's Avatar
You mentioned that you only have a 10GB hard drive. You'll probably want more space. Once you start getting a few songs on there you'll really fill it up quick.
If your budget allows get a 40GB or more 7200RPM (fast speed) Hard Drive. Then you can use the 10GB for you system files and your other one just for audio.
Tukkis
  #15
Old 04-15-2003
Tukkis's Avatar
Also here are a couple of programs that will tell you how many tracks you can have on your system playback and recording wise.
http://www.sesa.es/us/dl/dskbench.zip
http://www.west.net/~event/reporter.html
Tukkis
