Old 04-07-2003
newboy_bie newboy_bie is offline
Newbie
newboy_bie is on a distinguished road
dead room
i have a small room of about 8.5w x 12.5l and 9 fts high.... i just want to make it dead as i only want to use it to record strings, winds and other instruments except drums and all.... the walls are angled ... ceiling is sheetrock and floor is concerate one a very reflective...... i have two vertical corners giving me depth of aroung 16" .. i can make the wide band absorber also in the angled wall if it is necessary .... i initially thought to make it dead by absorbation material like rockwool or something....... what i have interesting in my room is that one of my wall is framed like a pyramid diffuser in which i am getting air space veriy from one point to another... i think its' good to be make highs live and must be that shape helps me out....... ny suggetions?
Old 04-07-2003
Ethan Winer's Avatar
Ethan Winer Ethan Winer is offline
Why 2K?
Ethan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond repute
Lightbulb Re: dead room
New,
> i only want to use it to record strings, winds and other instruments <
To record strings in a room that tiny my advice is to keep the cement floor, but make every other surface as dead as possible, including the ceiling.
--Ethan
Old 04-07-2003
Newbie
kewl
i have cement floor... should i put carpet on it? i am planning to make it full with mineral wool and covered with sheetrock... the ceiling is already sheetrock and insulation inside.... wht abt if i have remain some walls without sheetrock and only cloth covering?
Old 04-07-2003
Newbie
ny feedback.....
waiting for feedback.....
luv
Old 04-07-2003
Eric Best Eric Best is offline
Junior Member
Eric Best is on a distinguished road
No Carpet!
The carpet will only absorb high frequencies, also a highly reflective floor will give some life to the sound. You could use vinyl flooring.
Eric
Eric
"Give a man a fish and he'll eat for a day, teach him to fish and he'll buy a boat and drink beer for the rest of his life"
Old 04-07-2003
Newbie
ok.
So r u agreed on the way of construction i am going for..... i am using 3" insulation rockwool.....
Old 04-08-2003
Why 2K?
Lightbulb Re: ny feedback.....
New,
> waiting for feedback..... <
Didn't you read what I wrote? Keep the cement, or cover it with vinyl or something else that is reflective. A hard floor and all else dead at all frequencies is a good way to treat a small room for recording acoustic instruments.
--Ethan
Old 04-08-2003
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
Is it OK to do the opposite, deaden the floor and make the ceiling live? I have a very similar room, but for many reasons I'd like a carpeted floor. Thoughts?
Old 04-09-2003
Junior Member
By putting carpeting on the floor you will only deaden the high frequencies, your recordings will come out dull and boomy, you need to have balanced absorption all across the entire spectrum. There is nothing you can put on a floor to evenly absorb, so you must put it on the ceiling and walls.
Eric
Old 04-09-2003
Newbie
diffusion
i think by framing shapes like diffusers can be helpful to make highs alive .... any suggetions?
Old 04-09-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Read here --> http://www.saecollege.de/reference_m...Acoustics1.htm
  #12
Old 04-09-2003
Why 2K?
Lightbulb
M,
> Is it OK to do the opposite, deaden the floor and make the ceiling live? <
That's not so good if you plan to mike things from overhead, where the mikes are close to the ceiling. You'll may get severe comb filtering (sounds like a flanger effect) from reflections off the ceiling into the rear of the mike.
--Ethan
  #13
Old 04-10-2003
ted88 ted88 is offline
Newbie
ted88 is on a distinguished road
dead room, no problem
Careful not to make your room too dead! If you use an acoustic treatment, use one that you can easily adjust.
