Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 03-31-2003
L'espion Noir L'espion Noir is offline
Force of Nature
L'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond reputeL'espion Noir has a reputation beyond repute
What could it be
im recording each side of a cassette tape onto cubase as one audio track then mixdown that track
and export it to wavelab to be divided per song and burn to cd
i did it for the side A
but when i try to do the same for side B there is no graphic representation of the mixdown on the mixdowned track eventhough it went to the process of creating it (i.e Blue bar of progress)
all i get is just 2 flat lines (death) no sound
Can someone tell me what my other hand touched
Thanks
Old 03-31-2003
pratt's Avatar
pratt pratt is offline
Dedicated Member
pratt has a reputation beyond reputepratt has a reputation beyond reputepratt has a reputation beyond reputepratt has a reputation beyond reputepratt has a reputation beyond reputepratt has a reputation beyond reputepratt has a reputation beyond reputepratt has a reputation beyond reputepratt has a reputation beyond reputepratt has a reputation beyond reputepratt has a reputation beyond repute
why not just record it directly using wavelab?
Old 04-02-2003
Force of Nature
record directly from the stereo ? im trying to do that thru the manual
Old 04-02-2003
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
What are you using for recording the cassette? It sounds like a panning issue.
Old 04-02-2003
pratt's Avatar
Dedicated Member
Question
this is confusing? you have both wavelab and cubase on the same computer, right?
assuming that's the case - you can set wavelab up to record via the same interface that you are using to import your stuff into cubase...
on to your other point - when you play side b of the tape - are you getting levels in your recording program? what soundcard are you using?
Old 04-03-2003
Force of Nature
i do see the levels when i record side b
i have a Q10 for soundcard
this is how i'm recording from the stereo
got a 1/4" going from the headphone jack on the receiver to 1 input in the soundcard
i record the sound from the soundcard into cubase as an audio track
this process worked for both side a and side b on 2 tapes
the bump is at mixdown
i did turned it down very low you think that could be a cause
i got one thing to check: the Background release
thanks for the replies
Guidance
Old 04-04-2003
Bass Master "K"'s Avatar
Bass Master "K" Bass Master "K" is offline
Force of Nature
Bass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud of
I know you probably have already thought of this and retryed everything, but did you make sure that when you went to mixdown that the locaters were set right?
Once I had them backwards so it looked like they were in the right spot, but the L locater was at the end of the song and the R was at the start. It resulted in flatlines if I remember right.
Another thing is making sure that you have the right boxes checked in the mixdown box that pops up before it processes it, ie: the mixdown what is between the locaters box and stuff.
I hope I understand your problem right, sorry if I didn't and this doesn't apply to you.
Old 04-07-2003
Force of Nature
you know i didn't check that but as soon i get some time imma check it out
thanks "K"
Old 04-07-2003
Strryder Strryder is offline
Force of Nature
Strryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond repute
Just to make sure here..
You are in fact using a "stereo" cable to get into your soundcard right?
How can you get a stereo signal into a single input on the Q10?
Are you setting up your recording software's track to record stereo?
