I have only been playing drums for about 2 years. Anyway i play extreme metal (really fast) so all my hits are not as even (volume wise) between slow to fast, I try to track as hot as possible and was thinking of using my behringer's(mdx2200) peak limiter funtion while recording on snare and kick to control those certian "bashes" that clip into the red. Would this be a good idea? does anybody use a limiter when recording a drummer thats not so constant ? Any pro's and con's? Im not into using compression while recording.
If you like the sound of that on the recording, it makes sence to go ahead and use it then.
But when in doubt, it might be safer to compress after, and use lower record levels. You didn't say what you were recording on. 24 bit? 144 db is a lot of spare room. Wayne
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini (formerly S.P. Technology |
24 bit on protools via digi 001.
Do not limit!
Lower the gain to avoid peaks, recording at 24bit you have a lot of headroom. Amund
Amund Blix Aaeng www.pdstudio.no |
Slowly, the message spreads.
Hot levels are not necessary. ![]()
really?
Their is only a couple snare hits that makes the track clip.
Why not limit? im all new to this recording digital on a pc, maybe becase tape is more forgiving? Ill have to lower my gain. |
Re: really?
Recording at 24bit, you do not need to record superhot. Amund
Re: Re: really?
Re: Re: really?
Re: Re: Re: really?
Having a clean signal path is always important, so why run the signal through an additional unit, just to catch a few peaks.........? Amund
Re: Re: Re: Re: really?
#12
Re: Re: Re: Re: Re: really?
#13
Re: Re: Re: Re: Re: Re: really?
#14
Re: Re: Re: Re: Re: Re: Re: really?
It isn`t fast enough to catch transients. Amund
Amund Blix Aaeng www.pdstudio.no Last edited by plexi; 04-01-2003 at 12:43.. |
#15
#16
Re: Re: Re: Re: Re: Re: Re: Re: really?
#17
Re: Re: Re: Re: Re: Re: Re: Re: Re: really?
But for me, it`s more than fast enough. Amund
#18
Now 2 RNC's, chained, might be fast enough to be used as a peak limiter.
#19
So what is a good limiter??
#20
curious.....do larger studios always use limiters on the drums when first recording? OR do they record at lower levels and use software and hardware compressors after to bring up the volume of the tracks?
#21
#22
But.... How 'bout making your own Look-Ahead circuit? Mult the line, one goes directly to the side chain input, the other goes through a good digital delay set -1 ms. You'd still have to watch your input levels into the delay but thats no problem (you got 144 db to play with) but now at least we could record nice and HOT. Wayne It's a joke, right.
#23
But here, again, we have those pesky conversion levels to tend to. (Still just having some fun with this here folks... I used the 'Peak Stop's on the 166's for years on snares without too much signal losses. But then again some said that Anything I ran through a 166 had signal losses. Wayne
#24
Re: Re: really?
#25
