Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 03-24-2003
twist's Avatar
twist twist is offline
1K Silver Member
twist has a reputation beyond reputetwist has a reputation beyond reputetwist has a reputation beyond reputetwist has a reputation beyond reputetwist has a reputation beyond reputetwist has a reputation beyond reputetwist has a reputation beyond reputetwist has a reputation beyond reputetwist has a reputation beyond reputetwist has a reputation beyond reputetwist has a reputation beyond repute
I need a new nut!
I need a new nut for a MIM Fender Strat with vibrato tailpiece.
I'm intrigued by the "roller nut" idea. Anyone know if these things are any good?
Twist
Old 03-24-2003
Tom Hicks's Avatar
Tom Hicks Tom Hicks is offline
1K Silver Member
Tom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant futureTom Hicks has a brilliant future
I have a Charvel strat copy with a roller nut and I love it. There is no binding of the string with you use the whammy bar, the strings rolls effortlessly and smoothly on the nut. It is a very simple and clever idea. A big thumbs up.
Old 03-24-2003
twist's Avatar
1K Silver Member
Thanks Tom, do you know the best way to remove the old nut? Are they glued? I have a "Sawzall" if necessary
Twist
Old 03-24-2003
Even's Avatar
Even Even is offline
Force of Nature
Even has a reputation beyond reputeEven has a reputation beyond reputeEven has a reputation beyond reputeEven has a reputation beyond reputeEven has a reputation beyond reputeEven has a reputation beyond reputeEven has a reputation beyond reputeEven has a reputation beyond reputeEven has a reputation beyond reputeEven has a reputation beyond reputeEven has a reputation beyond repute
To remove a nut:
Gather the needed tools...
1/4 wood chisel (or thin slotted flat screw driver)
small strip of fine grit emery cloth
toothbrush
Clean area completely.
apply a focused mist of steam (teapot) to the nut for 20-30 seconds. Do this by holding the nut (flip your guitar belly up) in the mist for the half a minute. Do not steam it long or you can jack up your finish.
hurry hurry.. lay the guitar on a table and gently ease the edge of the chisel under the nut. Wiggle it in SLOWLY.
If its going great then go all the way through. If it gets harder to lift the nut, re-steam and give it another go.
let it sit for a minute then swipe the emery cloth in the seat a few times to clear off the extra glue. Don't get crazy, you are just removing the glue, dont sand any wood off.
Toothbrush out any mild dust that remains.
Tada... ready for new.
second means to remove nut:
Try to lift a Chevy 350 alone.
Old 03-24-2003
Tom Hicks's Avatar
1K Silver Member
great post,Even!
Let me reinforce his advise not to remove any material from the nut shelf.
Old 03-24-2003
twist's Avatar
1K Silver Member
Thanks guys! Sounds like a cakewalk!
Twist
Old 03-24-2003
TheGuitarMan's Avatar
TheGuitarMan TheGuitarMan is offline
Dedicated Member
TheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond reputeTheGuitarMan has a reputation beyond repute
I would go with a Graphtech nut instead. That in combination with Graphtech saddles will reduce spring breakage quite a bit.
Old 03-27-2003
Clive Hugh Clive Hugh is offline
Force of Nature
Clive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond reputeClive Hugh has a reputation beyond repute
I'll second TheGuitarMan, I have a "graphlon nut" which is a mixture of graphite impregnated with teflon. Sounds great, works great, cheap, what more can you ask for?
Old 03-27-2003
Dani Pace's Avatar
Dani Pace Dani Pace is offline
Why 2K?
Dani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond repute
I used to hate those little "ting" type noises while tuning or using a whammy, then I discovered graphite, wow problem solved, and graphite is not a lot more expensive than plastic.
