SX MIDI problem
I am a newbie here and have not found my answer yet, maybe somone can help me.
I have been using SX for recording and it is working for the most part. I would now like to use the sequencer instead of my on board Kurzwiel or akai. Problem is I can see the midi levels on send and receive but it is not triggering any of my modules or synths. Here is my setup AMD XP-1700 256 RAM Aardvark 24/96 Sound card/ Midi interface Midiman 1/4 thru box akai mpc2000 kurzweil k2vxs ensoniq ESQM sequential Multi-Trak alesis Midi-Verb Zoom 1204 Even if I plug it right into my akai it still wont work. any suggestions? Thanks- Jason |
well I´m not shure I understand your question, but
if your recording midi from your outboardsampler there are several issues that could be the problem 1: if you are using your outboards as sound source: have you checked your midi setup in the device setup menu are your machines audio output connected to the in´s of your soundcard (shurely they are). 2: if you are using them to trigger vst instruments are they correctly connected in midi in and out and is your rec button on the midi track , turned on ? well I tried I´m a newbie as well but my outboards are working great so I can only help from within my own experience. hope it helps I not good luck to you |
I ended up using my akai MPC 2000 for the sequencer.
It is a very easy step style. I won't be able to do as much with it but it will work for now. Thanks anyway- Jason |
