can i record this????
i have a audio cd that is for my pc only. i would like to make a normal cd out of it so i can play it in any player. i dont think i can burn it with the computers cd drive(or at least my try failed)
so can i hook up my masterlink to my computers speaker output jack and set levels and go? i dont see why not. thanks guys! |
If you have spdif on a soundblaster card try to use the digital connectors for a digital audio transfer.
Though I don't know why you couldn't just burn a wav. format audio CD, it should work fine. |
no luck with the wav file and no digital connections on the pc.
if the speaker out is line level than my idea should work. |
SPEAKER OUT IS NOT LINE-LEVEL......
Don't EVER do this unless you don't happen to like the circuitry of the input-stage of whatever gear you try this with...... you WILL blow your inputs.
bruce valeriani recording articles http://www.bluebearsound.com/images/bb_siglogo.jpg |
to copy a cd to a cd that can be played on most any player:
1: Aquire the desired songs from the original cd to your hard drive. Handy program for this is "Audiograbber". 2: Convert the song files that you nabbed to WAV format. Handy program for this is MP3toWAV convertor. 3: load a blank CD-R (not a cd-rw) into the drive. 4: Open your recording software (Adaptec or Spressa or whatever).... select "audio CD" 5: Drag and drop the converted wav files to the menue" 6: click Test and record... 7: Get a beer 8: take the spiffy new cd, Mark it or be eternally confused.... and pop it in the deck in the other room. If this fails then there is a chance that you are attempting to duplicate a cd that is "watermarked" or write protected. |
thank you even and blue bear!!
