Old 03-21-2003
Skycries57 Skycries57 is offline
Senior Member
Skycries57 is infamous around these partsSkycries57 is infamous around these partsSkycries57 is infamous around these parts
Effects in "split" tracks, perameters?
Was wondering how can you tell what effects are in tracks or "split" tracks? My problem is upon splitting a track to say...2 seconds, then add in an effect then leave it, then come back to it 4 minutes later to see the parameters on what you set the effects at... it will not allow me to see what I originally "SET" the effects at? In Wavelab 4.0, you right click and it says "view" effects and your parameters. Why can't Sonar do this in the "add audio" effects section, I know you can view effect perameters in the far left track effects but not in "split track" effects.
HELP! Thanks! Peter ><>
Vintage gear slut for the millenium.
Old 03-22-2003
moskus's Avatar
moskus moskus is offline
The Creator of Æ, Ø and Å
moskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond repute
You mean the name of the preset disappear?
That has something to do with DirectX itself, and don't blame Cakewalk for it. You should talk to Microsoft.
And explain what's different between a "split track" (?) and a normal audio track.
Two wrongs don't make a right, but two Wrights once made an airplane...
Old 03-22-2003
Senior Member
...Upon right clicking say on track 1, I choose the option "split" , which in turn will split the track anywhere where I have the "starting line", this way I can take 2 or so seconds of the 5 min track and add effects,fade,etc to JUST TO THAT 2 seconds. After I "print" the effects onto the "designated 2 seconds" of that track, I will sometimes go back to that 2 seconds to see what I have set the effect perameters at, well it will NOT let you see what you have set them at, it looks like it DEFAULTS the "visual" settings. You may be able to HEAR your personal settings, but not be able to SEE your settings. Hope this clarifies things.
Thanks! Peter ><>
Old 03-22-2003
moskus's Avatar
That's right, you won't be able to see the settings. The effect is allready applied to the clip and closed afterwards...
You need to store the settings in a preset to get them back. Write a name in the box at the top, and click the disk icon. Now you can select them later...
Old 03-22-2003
James Argo's Avatar
James Argo James Argo is offline
Fancy Rock N' Roll
James Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond repute
Thumbs up
...and if you use SONAR 2XL, you can download SONAR Plugin Manager 1.0 from their site. Trust me, it's usefull...
Keep Rockin' and Rollin'...
