Old 03-18-2003
musicfan1234 musicfan1234 is offline
Newbie
musicfan1234 is on a distinguished road
latency problem
Hi,
I have a Delta 44 sound card and Cakewalk Sonar 2.0. I just got it all set up and i tried to record my bass just for a test run. The problem i have is when i run my guitar to my mixer and the mixer to the soundcard there is latency in sonar. We downloaded new drivers from the delta website but could never figure out how to change the old driver to the one i just downloaded. And im not even sure if that is the problem. Any help would be very much appreciated.
Thanks,
Billy Reynolds
Old 03-19-2003
moskus's Avatar
moskus moskus is offline
The Creator of Æ, Ø and Å
moskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond repute
I don't have a Delta Card, so I can't help you with the installation of the new drivers. But you should first set the latency buffer setting (or similar) in the Delta Control Panel to a low number, say 128. Then open Sonar and under Options -> Audio, hit the Waveprofiler-button. After it's done, it should set your latency to a low figure... If not, you can modify the latency yourself by using the latency-slider (but be carefull for dropouts, if you get them then raise the latency again)...
Two wrongs don't make a right, but two Wrights once made an airplane...
Old 03-19-2003
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
How do you know you have latency problems, musicfan? And do you have Input Monitoring enabled?
